Question about Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522
The water is not draining when i hook the hose up to it. how do i drain?
    Sergeant:
    Novelist:
  • 193 Answers
Is the water pressure on to the heater? If the water has been turned off the heater will not drain unless you open another valve to allow air to enter the heater as the water drains out. You can do that by turning on any hot water faucet in the house or by opening the safety pressure valve located on the top of the water heater. If that does not release water, check to be sure your hose from the heater is not kinked anywhere. If pressure is on to the heater and water does not come out, you will have to take some more drastic actions to drain the tank. You may have to actually remove the faucet at the drain and dislodge calcium build up in the bottom of the tank. If it is that severe, I think I would just leave it alone rather than take a chance of damaging the unit.
Posted on Oct 13, 2010
I have a Whirlpool water heater, the drain valve is plastic and has split into at the hose connection, I want to replace the plastic with a brass valve. How do I drain the water?
Most water heaters have a drain on the bottom where you can hook up a garden hose and run out side. Or you can get an air compressor and hook the air line to an open hot tap and put pressure and run the water out another hot tap. Close all taps but these two and make sure the cold water inlet to the tank is shut off.
Jun 26, 2017 | Whirlpool Water Heaters
Brass drain valve not working.
they get stopped up leave pressure on tank don't shut cutoff off hook up hose and run to outside then open drain valve with pressure on it for a min. it should flush.
May 03, 2016 | Water Water Heaters
Low hot water pressure only
turn the heat down or turn to pilot mode. Turn water supply off, hook up hose to drain valve, route hose to safe place to drain, v if this is above grade the don't turn the water supply line off. Open the drain and see how well it flows. There could be calcium deposits in the unit. IF it flows well out of the drain, you could have corrosion build up inside the inlet or outlet from minerals. Remove the inlet and outlet connections. Check for debris, you may have to replace the washer on the unions. Check the anode on the unit.
Nov 23, 2015 | Water Water Heaters
Popping noise in water heater. What is it and how do I fix it?
What is probably happening is that you have a build up of minerals on inner tank lining and when unit is heat it expands the tank and the deoosits at a different rate which is what is causing the popping noise.
I would turn power off to your heater and hook a garden hose on to drain valve.Route hose to safe area as the water being drained will be hot. Open drain valve and see if you can get it draining good.If it is then shut off water supply to heater and open hot side of faucet nearby to prevent vacumn from slowing down draining. I would drain as much as I could then close drain valve and faucet and refill tank. I would do this several times to try to get all sediment flushed out.Hopefully this will help with your noise and make your heater last longer and work more effceiently. Good luck and thank you.
Feb 13, 2011 | RELIANCE ELECTRIC WATER HEATER
How do you drain the whirlpool hot water heater opened the valve at bottom nothing coming out
WOW!! It must really be clogged. Hook a garden hose up to that bottom valve and run a short burst of water through there. mabey that will break it loose
May 13, 2010 | Water Heaters
Need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
Jan 26, 2010 | RELIANCE ELECTRIC WATER HEATER
I'm flushing my radiator in ford e-350 v8 with 5.4l......has strait water in it now......when i flush I'm trying to figure out where the heater return hose isto flush the core or do I even need to...
when i flush my radiator.i would first drain out all my old antifreeze.fill radiator up with water then put a bottle radiator flush. pour in radiator.then i will crank car up turn on heater wide open allowing radiator flush flush out radiaator and heater core when done i will drain out water. put in more water flush out all radiator flush out engine and radiator.then put back in antifreeze.you dont want to run water hose to heater core it will rupture it water pressure too high.
Dec 08, 2009 | Water Heaters
Hello, how I remove the water from my whirlpool jacuzzi bath Balboa Z112 spa so I can clean it
hook up a garden hose to a faucet. Put the other end in your spa. Then turn on the faucetuntil water comes out the spa end of hose. Make sure the end in the spa is weighted down so it doesn't come out. Then remove the hose from the faucet and keeping it lower than the spa lay the hose where it can drain with causing problems. The water will flow on its own draining the spa. You may want to clean it while its draing so the dirty water will be diluted and drain at thhe same time. Make sure the water is not drained out around any electrical AND!!! NO DIVING!!!! If you lose the prime, just fill the hose again with the faucet. Good luck
Jun 12, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Whirlpool electric water heater wont drain
I had a message from the smart energy controller on my Whirlpool Water Heater that my lower element was failing. I turned off the power and hooked a garden hose to the valve on the bottom and opened the valve with a 1/4 inch screw driver.Nothing happened! I thought the valve was plugged with settling hard water particles. The water heater was in a closet and I couldn't just let it run out onto the floor.
I was out in the garage looking around when I spotted the bicycle pump and found a female jet hose end that could work. Using a small piece of plastic tubing to connect the bicycle pump to the hose end with clamps( I had to remove the bicycle pump hose) and the other end of the hose to the water heater about five pumps and I could hear the gurgling of the air inside the water heater. I disconnected the hose end and put the hose outside to drain. Voila!
Nov 19, 2008 | Water Heaters
Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522 Logo
151 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
