Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a Kenmore Elite H3 Model 110.42822200 and the seal shredded so I just finished replacing the seal and now the control locked light is on. I tried the drain/spin technique also unplugged it for 2 hrs and still nothing. Any ideas would be great as our laundry is really stacking up now.
jsrock516
  • 5911 Answers
SOURCE: Control Panel
I believe the DRAIN/SPIN button on the Kenmore Elite HE3 will clear a locked control panel if you hold the button in for 3 seconds. This is actually a safety feature to keep small children from playing with the buttons and allows the consumer to lock the control panel. I hope that's all the problem you have and that it is not a control panel failure. Let me know if this helps. PS The matching Kenmore Elite Dryer uses the AUTO DRY LEVEL button for the same feature.
Posted on Jul 19, 2007
  • 1294 Answers
SOURCE: Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Posted on Jan 02, 2008
  • 156 Answers
SOURCE: Kenmore HE4t Washer stuck in "controls locked" mode
you need a new cpu you can unlock door by removing bottom panel reaching up to the door lock and pulling a little ring on the bottom will manualy unlock the door
Posted on Mar 03, 2008
SOURCE: kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Posted on Dec 30, 2008
ldsaunders
  • 31 Answers
SOURCE: Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Posted on Feb 12, 2009
Kenmore elite model # 110.45088400. We set a cycle, washer starts beeping and reads F then blinks to DL. We hit pause to clear then try to restart while it makes clicking sounds and it continues to read...
'DL' stands for Door Lock error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 24, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite washer - control light is on and ii cannot do anything? Please help how do i unlock this feature??
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 29, 2010 | Kenmore Elite 45986 Front Load Washer
WHAT IS A CL CODE ON MODEL 796.41022900 FRONT LOAD KENMORE ELITE WASHER,IT SHOWS INTERMITTENLY DURING WASH CYCLE
Means someone put it in controlled lock position. Just hold the Control lock button down for 5 sec or so until the light comes off. Machine isn't malfunctioning.
Jul 31, 2010 | Kenmore Elite 45986 Front Load Washer
Contol Locked
Jul 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washer 110.45981 400
Hold down 'end of cycle' for 3 seconds. Power shd be on.
Feb 09, 2009 | Kenmore Elite 45986 Front Load Washer
I am getting "CI" on the display even with an empty load cycle?
Jan 12, 2009 | Kenmore 20172 Top Load Washer
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Does a Kenmore Elite H3 dryer have a pilot Light???
No. They are electronic ignition. just plug it in and hook it to gas and should heat up.
Nov 21, 2008 | Frigidaire FGQ332ES Gas Dryer
Kenmore elite h3
I have an H3 washing machine and the rubber bellow lip that seals the front door from leaking has torn causing water to leak out. Can this bellow be repaired or easily removed and replaced without calling a service repairman.
Nov 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore elite h3
F/DL means the door lock.  If you take the bottom panel off (there are 3 screws), you can reach up and pull down on a lever to release the lock.  Next you need to take off the top of the washer (there are 3 screw on the back).  ONce you have the panel removed, you can see the wires and where they plug in at the back right area.  If you just jiggle them, you can get it to work again.  I am doing this right now until I can get a new computer.  My neighbor has a front loading washer of a different brand and experienced the same problem I am having now.  She is the one who told me how to fix it.
Oct 12, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
124 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
