Question about RCA 32F531T 32" TV
Television has no power. outlet has power and cord from outlet to television has power. is there a fuse?
    Top Expert:
  • RCA Master
  • 75,283 Answers
All telivisions has fuses inside. Some of them has one, and some has two. If your tv doesn't power on, and power chord and outlet is ok, surely the fuse inside may blown out. There may be some reason for the blowing of fuse. Fuses are used inside tvs are for protection purposes. f any overvoltage or over current taken by the system, the fuse will blow out. you must fist find out the resom for the bowing of fuse. New fuse must be put in only after that check. Otherwise you will spoil the whole circut board inside the tv irrepairable. Concat a service personnal, and let him do that. Ok.
Remember, different tvs have different power ratings. Must select proper fuse according to the ratings.
Posted on Oct 14, 2010
No power to TV
First thing to do if your television have no power is check the power outlet,then the AC cord continuity.If the ac cord have power supply,check the fuse,maybe the fuse is busted.Its is located at the power supply.So try to remove and open the back cover of your TV and look the power supply and replace the fuse if busted.Replace same value of fuse.Try this procedure,hope it will help you.Thanks..
Aug 26, 2011 | Panasonic Televison & Video
Screen went blank while still on. unplugged power cord and when I plugged it back in the power on light went green. Problem remains
Resolution:
Follow the steps below to troubleshoot this issue.
Verify that the AC power cord is connected securely to a working wall outlet.
Unplug the power cord of the television from the AC outlet.
Let the television remain without power for 1 minute.
Plug the power cord back into the AC outlet.
Attempt to turn on the television.
NOTES:
If the issue is still unresolved after completing all of the troubleshooting steps, service will be required.
Make a note of the STANDBY or TIMER flash pattern when referring the television to service.
Aug 13, 2008 | Televison & Video
I have a 46" Flat Screen TV. Model Number
First thing you do is to check the outlet if there is a power output the check the power cord and plug.If there 's a power in the power cord,Check the fuse of your television.The fuse is located at the power supply.You can see the power supply when you open the back cover of your television at the upper right side.Replace the fuse if busted with the same value of fuse.That's the step you can do first..Thanks..
Aug 25, 2011 | Televison & Video
HAS NO POWER AT ALL
If your television is totaly no power,first step to do is to check the power outlet if there's a power output.Then check the power cord,if good,the problem is inside the television.Maybe the fuse is busted.So remove the back cover of the television and find or look the power supply.The fuse is located at the power supply.Replace same amphere of fuse if busted or open.Try to power on if you already replace fuse.Thanks...
Aug 21, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Tv will not come no timer lite blinks
Things You'll Need:
  • Electrical outlet
  • Fuses
  1. Check that the power cord is securely plugged into the power outlet.
  2. Make sure that the power outlet is receiving electricity by plugging a different device into the plug and turning the power on. If the other device does not work you likely have a blown fuse or tripped circuit breaker.
  3. Replace the blown fuse or reset the circuit breaker as needed. If it happens again, an electrician should assess the problem.
  4. Contact akai Support if Steps 1 to 3 do not solve your problem. Only a trained service technician should attempt to fix the power problem with your television
Jan 22, 2011 | Akai PT46DL10 46" HDTV-Ready Television
Will not power up
If your television will not power up, there is just one problem related to this, and that is the power panel. But before You confirm it is the power panel, You will have to run a test on some components to be sure that it not other components before You go ahead to replace the power panel of the television. The components to tests are the power outlet, check if the voltage is not too high or too low to power on the television. Then You also test if the cable that connects the television to the power outlet is not bad by using it on another television and trying to use the another power cord on the television, then You confirm if it is not a blown fuse on the power cord. Once that is confirmed, then You can go ahead to replace the power panel of the television. To replace the power panel:
  1. Get a screw driver, a glove a cup and a replacement power panel,
  2. Unplug the television and put on Your gloves,
  3. Turn to the back and unscrew it open,
  4. Keep all screws in the cup in order for them not to get missing,
  5. The power panel is the panel that the power cord is attached to at the back of the television, remove it,
  6. Fix in a new one
  7. Reverse the process to reassemble the television back together,
  8. Plug it into the power outlet and power on the television.
It should turn on now.
Hope this helped. Thank You for using FixYa!!!
Jan 21, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
The television doesn't turn on. no led's are lit.
check your fuse in the power supply, make sure you unplug the power cord from outlet.. check your cable too. If no lack, then the powersupply board is bad
Aug 26, 2010 | Westinghouse SK-19H210S Television
No power
If your television has no power, try the following:
1. Check the power cord for breaks, tears, or exposed wires .
2. Check to be sure that the power cable is fully inserted in the outlet and that the outlet is working.
3. Go to your fuse box or circuit breaker box and check the fuse or circuit breaker of the circuit your TV is plugged into. Replace the fuse or reset the breaker if necessary.
4. Replace the batteries in the remote control, and then try turning on the TV using the remote.
5. Unplug the TV, wait five minutes, plug the TV back in, and then try turning on the TV.
If the recommendations above do not resolve your problem, most likely the power supply in your TV has failed and your television needs service.
Thank you !!
Jun 04, 2010 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
Panasonic television
I had the same problem, however mine was a 32inch. It is a blown fuse. It is not the power cord. What you need to do is find out what fuse voltage you need. Hope this advice helps. I have a panasonic model CT-32SX12C.
Aug 20, 2008 | Panasonic CT-36SX12 36" TV
RCA 32F531T 32" TV Logo
98 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
