Question about CSi Speco Speco Technologies DVR-4CF 4-Channel Digital Video Recorder with Compact Flash Slot
Dvr will not record. i get the message, " hard drive full" is there a way to erase what is on the hard drive?
  • kcool125 Oct 14, 2010
    Cindy,
    Thank you for the info. I tried both suggestions and neither seemed fix the problem. I'm now getting a message that the HDD can't be detected. Is it time for a new DVR or can the HDD be replaced?
    Thanks - Kevin
  • 5,190 Answers
You can erase the contents of the drive or set the drive to overwrite when full. Erasing the drive is the equivalent of reformatting (you will not be able to recover the images easily).
To Erase/Format, enter the Menu system and select Hard Drive Setup (seventh line in the list). Press Enter, then go to HDD Format (fourth item in the list) and press Enter. Then enter your password (set up under System Setup) but the default password is 111111, if it is on. If you entered the correct password, the screen will flash HDD Formatted 3 times. Press Menu to exit the menu. (If the incorrect password was put in, Incorrect Password will flash.)
To overwrite, again go to Hard Drive Setup then select the first item, Drive Full. Press Enter to toggle Overwrite On or Off. You will be able to recover the images until they are overwritten.
I hope this helps.
Posted on Oct 14, 2010
  • Cindy Wells Oct 15, 2010
    The hard drive is removable. However, without knowing why the HDD is not being detected, I can't tell if the drive went bad or the controller. The first thing I'd try is to eject the HDD and then reinsert the unit.
    The drive is in a removable box; so you need to pull that box and then swap the drive with the same size (2.5" probably but I've never had the drive fail before without other symptoms) and type (IDE/SATA). You could also try a new swappable enclosure.
    BTW there is a 3-year warranty on Speco DVRs.
    I wish I could be of more help.
All saved recordings have disappeared from menu. system has reset itself and now all recording in the HDD play menu have disapperaed. They must still be on the HDD because nothing else has been...
dissambling and taking the hard drive out of the dvr will most likely void the warrenty how it is possible.
once the hard drive is removed you may be able to plug it into your PC and gain access to the files on the hard drive. These how ever may be specially encoded and protected files that you cant open.
-you PVR may have also done a hard reset and formatted the hard drive. This would delete all the files on the PVR.
-unlike tapes, erasing a hard drive does not require you to record over it. just because nothing else has been recorded does not mean your data is still there. sorry.
Mar 01, 2011 | Pioneer DVR-720H-S DVD/HDD Recorder
Hi we have inherited a Pioneer DVD Recorder DVR -530H. I have no instructions - the foxtel guys has hooked it all up to the TV however I cant work out how to clear all the recordings that are stored on the...
  1. You must be in the Disc Navigator (HDD)
  2. Highlight the title you want to erase.
  3. Select 'Erase' from the command menu panel.
  4. Select 'Yes' to confirm or 'No' to cancel, then press ENTER.
  • You can also Highlight the title you want to erase, press clear on the remote, and press ENTER.
Here is your manual: http://www.pioneer.com.sg/storefront/manual/DVR-530H.pdf
Feb 28, 2011 | Pioneer DVR-3100 DVD DVD Recorder
Un able to record. message says hard disk full
If you have a DVR you need to delete some programs you recorded on it before you can record. Your hard drive on it is full.
Dec 07, 2010 | Televison & Video
I can not put a desired event on recording thru"create timer"scre
aparfenov
The receiver hard drive is comparable to a computer hard drive. When a problem is detected with the hard drive, the receiver will give an error message stating a problem has been detected. Depending on the severity of the problem, sometimes it will show that unplugging the receiver for 1 minute will resolve the issue. Other times, a message will state that the hard drives needs to be reformatted, which will erase all content on the hard drive. It sounds like this is what happened to your recordings. If unplugging the receiver did not resolve the issue, we may need to replace the receiver. Please call 1-800-333-3474 and speak to a Technical Support agent.
Ray Calo
DISH Network
Apr 25, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Disk is full. Can not reset and erase the disk.
Hi !!
From your post Its not clear that either you are talking about Hard disk or Compaq disk. If its Compaq disc ( CD ) make sure its Rewriteable or if its hard drive make sure  nirtual memory is not allocated to that part and also no application or software is running.
Thanks Irfan
May 07, 2009 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Recording
I have the same problem. I believe this unit is a lemon by Samsung. I was so exhausted I went to Hard drive erase. After I erased the HD, now it will not record or go into recode mode. I think all it good for now is just to view the monitor. When I call Samsung they dont have a clue what a DVR is. I never seen a company so illerate. They cant even tell me where I can send it for repair.
Feb 12, 2008 | Samsung 4 Channel Dvr
Hard drive shows full even after erasing 120 hours.
You should empty the recycled bin in the system and delete all temporary files on it.
Jan 10, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
DirectTV Dvr Playback of Recording skipping and locking up reciever forcing Resetof reciever.
Have either of your tried unhooking the HDMI connector if you are using it and try component?
What software are you running on the unit. The HR20-700 and HR20-100 just got a software update that was going to fix this problem w/ the unplayable recordings.
stephnt:
If it is erasing your content that is a good sign of a defective hard drive. These units when they boot up (after a software update) check the hard drive. If they run into a problem (bad sector) they will foolishly erase the hard drive, thus erasing everything you have recorded. If this is your 4th unit, you may want to look at your environment as well (well ventilated, good connections, etc) I'm not saying it couldn't be the unit. It took directv 14 units to get 3 working, and since I've had 2 HR20-700 refurbs that were unstable and were quickly replaced.
It might be in your best interest to invest in an external drive solution for the HR20. I, however, would be calling customer retention and having a calm, but stern chat with them about this.
Nov 16, 2007 | Directv Plus DVR DTV Receiver / 100-Hours...
CSi Speco Speco Technologies DVR-4CF 4-Channel Digital Video Recorder with Compact Flash Slot Logo
394 people viewed this question
Top CSi Speco Televison & Video Experts
 Russ Hill
Russ Hill
Are you a CSi Speco Televison and Video Expert? Answer questions, earn points and help others
