Question about Microwave Ovens
How to re assemble a vintage rubbermaid two tier lazy susan brand # 2527
Is the blades supposed to come off when I take the container off of the blender.. My blender is brand new sat for 3 or 4 years after I bought it. . The first time I used it , it was extremely hard to get...
You did not specify a brand or model number of your blender; however, most blender jars will lift off their power base without turning or with only very little turning motion to release them from the base. The blade assembly should NOT come off as you remove the blender jar from the power base.
Were you successful in removing the bottom ring which normally screws on to the bottom of the blender jar from the powerbase?
You should make sure you have properly attached the blade assembly for your brand/model.
The blender blade assembly should be held on to the bottom of the blender jar by the bottom ring which screws on clockwise; most will have a sealing gasket that fits between the blade assembly and the sealing surface of the blender jar to prevent any leakage while in use. It will take much more turning to unscrew the bottom ring to release the blade assembly than it should to release the bottom ring from the powerbase.
Assemble your blender jar and blade assembly and try a dry run by placing on the powerbase, giving a couple of bursts of power, and then seeing if you are able to remove without the blender ring unscrewing.
Make sure you are comfortable with the action required to remove the blender jar from the powerbase before you put in to use.
Jul 31, 2011 | Microwave Ovens
We cant get our George Forman 3 tier food steamer off the warming function even when we press and hold the on off button
Try opening it, make sure it's plugged out and go over the wires and connections manually. Look at where the door shuts as well.
Apr 19, 2011 | Microwave Ovens
I have the coldless lazy susan buffet server LSB-Series. I need to order a new cord.
JustAnswer.com/Helman-Group
COULD NOT FIND ANY PARTS DISTRIBUTORS FOR HELMAN GROUP BUT TRY THE ABOVE AND SEE WHAT THEY SAY
Feb 06, 2011 | Helman Group Microwave Ovens
My convection/microwave quit rotating.
Hello Tina,
Usually those turn tables(or lazy Susan's colloquially) are driven by a small motor. The motor attaches to a gear or spindle which transfer the rotational energy to the turn table. A plastic gear may have been broken or popped loose. It might also use a belt to transfer the energy, the belt could have worn and is now slipping which would cause the table to stay stationary.
Aug 10, 2017 | Sharp R-370E 1000 Watts Microwave Oven
I Can't Find Microwave Glass Truntable Tray for Jenn-Air
Martin Microwave has one in stock here for $25.99.
I searched for model JVM8000 and this came up.
On a related note, I think that what Smithbrother was talking about is something like a Micro-Go-Round. Here's a related post from my "Ask Mr. Microwave" page.
Q. My turntable is missing or unavailable. What can I do?
A. This sort of arrangement can be a good temporary fix until a suitable replacement tray can be found, or even a permanent solution.
Place a microwave-safe saucer upside-down over your roller ring / turntable support assembly. Then place a microwave-safe plate rightside-up atop the saucer.
Be sure both are centered, checking them frequently to be sure shifting does not occur. Otherwise, a spill of hot material could result. Safety first!
Another option is to check Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware wind-up turntable such as the Micro-Go-Round.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Dec 30, 2008 | Welbilt MR755T Microwave Oven
Turntable shaft
In case some local appliance shops or appliance parts stores may have one setting duty on the shelf, the part number was 58001050.
Do you still have the old part? Can you post a photo of it?
J.B. Weld brand epoxy might fix it, if applied sparingly... you may have to get creative...
You can check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round". (I've seen them at Wal-Mart recently). It's shown below.
If you find one, you can plug the shaft hole with a rubber plug from the hardware store and use this.
Aug 28, 2008 | Maytag UMC5200BA Microwave Oven
Broken Glass tray
That model number isn't showing up. Could you confirm that?
Then I'll see if anything is still available for it.
Otherwise, here are two suggestions:
You place a microwave-safe saucer upside-down on the roller assembly (if equipped) and then put a microwave-safe plate right-side up on top of the saucer. You can also use another glass turntable tray that doesn't fit instead of the plate.
Another option is to check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round".
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 10, 2008 | Microwave Ovens
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
