Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Freezer doesnt work
I have the same problem with mine. i had to take all the food out of the freezer because it was melting. the refrig is cool at best. how do i fix the timer or replace the gear?
FRIDGE NOT WORKING
Posted on Jun 16, 2008
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
Maytag model MBR2258XES4 refrigerator and freezer not cooling well d
I had a similiar problem with mine..it ended up being the defroster board..it seems to kak out every 3 yrs..mine was under the temperature control panel..it was in a white box inder the cover..good luck.
Mar 25, 2014 | Maytag MBR2258XES Stainless Steel
Kenmore 18tfa top freezer refrig model # 72852101 freezer works, no cool air going into the refrig part. Ice machine works fine too. fan is on.
Possible fan not blowing the air into the fresh food compartment or your freezer could be frosted up. Need more input.
Jan 29, 2011 | Kenmore Refrigerators
Refrig. Won't keep food cold but the freezer works fine. Milk spoils after 3 days in the refrigerator. What's wrong? The thermastat was supposely changed?
If the thermostat has been replaced, then I would take a look at the dampers between the refrigerator and the freezer. Here is why....
All the cooling takes place in the freezer section of the unit, there are passageways with dampers that connect the freezer section to the refrigerator section. If these dampers get stuck in a certain position you will either have not enough cooling or to much cooling. This sounds like it is your issue. Hope this helps.
May 07, 2010 | Refrigerators
Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Jul 26, 2009 | Freezers
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
101 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
