Question about Orbit Sprinkler System Power Source Transformer #57040
The watering station will not start, it says power off. Could it be the transformer, part number 4115E26T?
I want to use my USA Dremel Stylus in Europe. I already ruined a docking station, using my 110-220 transformer. I now have a new dock but what type of transformer should I get? Dremel says it should put...
I presume you want to use a transformer to convert the Europe voltage to USA voltage ( 220 or 240 to 110 )
Why not purchase a 240 volt docking station ?
Send me the 10 digit number on your Dremel (usually starts with F ) and I can help you.
Oct 09, 2013 | Dremel Drills
Manual test does not work Looks like it does but water does not come on
If the manual test doesn't work, I think the auto function won't work either. If that is true, your timer is running on the battery and there is no power. Remove the battery and see if it appears to be working. If not, check your outlet to ensure that there is 120 volts ac. Plug a light or shaver into the outlet. If the outlet is good and the clock has no power when the transformer is plugged, you probably need a new transformer.
Gary
Sep 26, 2011 | Orbit 57882 9 Station Super Dial...
Rain drop has saying printed in it"no power" power
First of all, remove any backup battery in the timer.
Now it should go blank.
If this is so, check the outlet first with another device like a lamp.
If the outlet is ok, the transformer may be bad, giving the timer no electricity.
Gary
Jul 12, 2011 | Orbit 57882 9 Station Super Dial...
I have a harvard hydro saver 7 automatic controller. I have two stations with red lights, nothing works.
hello this means the solinoid is bad. inside the water box on top of electric water valve. shut water off at the street than unscrew solinoid there is two wires cut them than reconnect to new solinoid. look at wire colors so u know what solinoid is bad.
Jun 09, 2011 | Orbit Sprinkler System Power Source...
My Grundig Satellit 700 Radio is not working on FM Band but is working well on AM and Shortwave Band. After pressing ON/OFF button and FM/RDS-AF button when we try to operate the FM Band of this radio...
As a side note, most AM/FM radios use a separate antenna for each band, thus why you can pick up AM but not FM. Check your mast antenna connections to make sure they are solid and not missing or loose.
Dec 10, 2010 | Grundig Audio Players & Recorders
I have a Orbit 57161 Sprinkler System 6-Station Standard Indoor Mounted Control Timer with rainbird sprinklers the issue that I have is the sprinklers stay on and don;t turn off.what do i do?
Manual:
http://www.orbitonline.com/lib/media/57114-14%20rF_Eng.pdf
Website:
http://www.orbitonline.com/products/Timers/02/01/19/671/
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Oct 04, 2010 | Orbit Sprinkler System Power Source...
WIRING INSTRUCTIONS for MTH gas station A
A) on the gas station gets one wire from the transformer and one to the activation botton off A on gas station ( acc power from transformer )
B) gets ground from the transformer
C ) to activation botton
D ) to Acc power on transformer
E ) ground on transformer
Dec 27, 2009 | Mth Toys
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Blown transformer
I also have the GPX under-counter TV, same problem. I believe the transformer is AC-AC, because both wires out are red... I actually have two of these units, one doesn't work at all, the other has enough power to play the radio, but not the TV. I swapped the transformer from 1 into the one that was completely dead thinking #1 had a bad tuner, but the same symptoms exist now in #2, making me think that one transformer is completely gone and the other is malfunctioning. I'll try the VX 79NP on both and try to remember to post the results back here....
Jan 16, 2009 | Curtis KCR2610 7 in. Portable Television
Orbit Sprinkler System Power Source Transformer #57040 Logo
85 people viewed this question
Top Orbit Hardware & Accessories Experts
appman67
appman67
 Kenneth
Kenneth
Andrew Taylor
Andrew Taylor
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
