Vertical roll in the picture on older tvs you can adjust the vertical roll is there away to do that on this model? its 2 white bars about 6 inches apart they constantly roll up the screen. is there a special box or cable i need to use for the hdmi? i live in a small town with 1 cable provider.
  • 144 Answers
As for the vertical stripes get a professional to take a look at that as for the hdmi you need a hdmi receiver or dvd player and connect to your tv via an hdmi cable to get the hd signal on your tv
Posted on Oct 14, 2010
My Sanyo Vizon 32 inch flat panel has times when part of the picture becomes a "white ghost". How do I adjust?
Actually that is quite a rare case on today's modern digital flat panel TV's. You're not saying where you live, and you're not saying if you have previous issues on older TV you had before digital, and (again) you're not even saying whether you're on a hill or deep into a gorge. No TV has ghosting these days, but if you're living in an area as above, go see the TV people and they will probably recommend a set top box. But that isn't really necessary if you have a modern flat screen TV because most of these TV do two things, they give you a crystal clear picture or they don't. Digital TVs have a channel searching system that does the searching for you, and, as the case may be, these only pick up the best channels that give the sharpest picture. Anything that is of poor reception they ignore, so you're actually missing all the channels available because of this ghosting issue. AN there is nothing to adjust on the ghosting, snowing and vertical or horizontal bars, etc. These issues are things from the past, e.g. old analog TV's.
Dec 28, 2014 | Sanyo Televison & Video
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
Yeah I have a Sylvania model # SP A2751 106. It is a old **** tube tv. When I go to hook up the the dvd player and switch it to vcr/aux the picture rolls in bars upwards. Its not the dvd player tried it on...
There should be a preset resistor on circuit board of old CRT based TVs, designated as vertical rolling adjust. Try to locate it and adjust a little till rolling stops, while playing the DVD. The set will be live during this process, so be careful. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 25, 2013 | Televison & Video
Picture roll up and down
Standard CRT televisions have a vertical roll adjustment,usually on the back at the bottom.
It may look like a white finger-knob (about the size of a pencil eraser) with a small screwdriver slot in the end...or it may be a roll-wheel...either way, it will be labeled "vertical" (or just "vert").
Make slow adjustment to the vertical until the roll stops.
*Use a solid signal for the adjustment, like DVD, VCR or cable...a weak signal can cause a bit of roll, too.
Apr 11, 2010 | Sony Televison & Video
27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
Mar 03, 2010 | Zenith C27A24T 27" TV
White lines at the top 3-4 inches of the screen.
well its all new now could be bad caps or vertical i.c. okay if you have a esr meter check around the i.c. for a leakey cap good luck
May 13, 2009 | Insignia NS- 27" TV27 TV
DVD picture rolls vertically
Somehow the TV setting on the DVD player was set to PALS so we changed it to the proper setting.
Dec 15, 2008 | Digix HT1056A DVD
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
Electro Med Services...
