Question about Fisher Paykel EcoSmart GWL15
GHL16US model has stopped spinning. It keeps adding water instead.
  • 3 Answers
Most of the functions are controlled from the motorized wash selector switch cluster and they are not user repairable, but usually can be purchased through the manufacturer's parts supply page or outlet store.
Posted on Oct 13, 2010
Whirlpool Cabrio 580 is unbalanced and will not complete a wash sequence
USEUALY IT IS MOST LIKELY THAT THE UNIVERSAL JOINT UNDER THE WASH PLAT AT THE BOTTOM OF THE TUB HAS GONE OUT .SHOULD BE REPLACED . THAT SAID PROBLEY WISE TO GET A TECH TO REPLACE IT . ON THESE YOU HAVE TO HAVE A SERVICEMAN TO REMOVE AND REPLACE THEM ..
Apr 25, 2017 | Whirlpool Washing Machines
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
My car won't start
-You keep adding water every couple days...? If so water leak to the engine. So the spark plug could get wet of water instead gas.
Mai Lor
Apr 13, 2013 | 2008 Dodge Grand Caravan
Wont spin drain or engage
Need more info. Brand, top load or front load, or full model number. Thanks.
Jan 19, 2013 | Washing Machines
LG Washing Machine Model : WD658 When using the function "Rinse & Spin", the timer decreases when rinsing. However, the timer decreases and stops at 9 minutes. This results the machine...
Try setting a lower spin speed. You may have a bulky load which the washer is having a difficult time getting up to the high speed spin you have selected. Also, did you know that on most LG washers, you can do just a spin without a rinse? Just turn the washer power on, then, without selecting a cycle, just push the spin speed selector to select the spin speed desired. This should set the cycle for about a 12 to 14 minutes pump and spin only. Then push start. You can spin that bulky load at the lowest spin, then try it again at the next faster spin if needed, without adding rinse water.
Mar 15, 2011 | Washing Machines
Cold water does not stop at set levels. Too much flow.
Blockage in pressure bottle or small hole in pressure bottle tube.
Feb 25, 2010 | Washing Machines
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
FisherPaykel GWL10US won't spin
diverter valve malfuntion water is recirculating instead of pumping out
May 28, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel EcoSmart GWL15 Logo
13 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
