Question about Proscan PS27108 TV
How to turn off closed caption using proscan 27108?
Agent Aaron
  • 265 Answers
SOURCE: PROSCAN 32LA25Q
Hey kjr_67,
According to information provided by the manufacturer, you may toggle closed captioning on and off through the "Function" menu. You should be able to reach this menu by doing the following:
1) Press the "Menu" button on your remote control to enter the "Picture" Menu.
2) Press the "Up" or "Down" arrow key until the "Function" menu appears and is highlighted.
3) Press either the "Left" or "Right" arrow key to enter the "Function" menu.
4) Press the "Up" or "Down" button to select "CCD", and the "Left" or "Right" arrow key to change this setting from "On" to "Off".
5) Press the "Menu" button again to exit and save any changes.
If you're still not quite sure how to proceed, I would strongly suggest referring to your owner's manual documentation for further information. You should also be able to find step-by-step instructions with visual aides by visiting the following link to the manufacturer's website:
http://www.oncorpus.com/down/ENG/32LA25Q%20English%20UM.pdf
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jul 02, 2008
SOURCE: Proscan Television
Operator erra.
Posted on Jul 23, 2008
  • 30 Answers
SOURCE: closed captions
In all situations I've seen:
A) It's an option on your cable/satellite box.
B) It's a broadcast signal and it's in the TV menu.
Posted on Sep 02, 2008
crayzeetrayn
  • 837 Answers
SOURCE: closed caption will not turn off on toshiba regza 46 hdtv
Try unplugging the TV for at least 5 minutes .. then try again
Posted on Jan 08, 2009
  • 16 Answers
SOURCE: How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Posted on Apr 02, 2009
I need remote control,
Google
Proscan 40LC45S57 remote control
Jul 18, 2014 | Proscan Used Original 40LC45S57 Remote...
There will be a button marked "CC" at the keypad of its remote control. Press it once, will make Closed Caption OFF, for an other press it will come again. It is a toggle switch to CC. Gopakumar Gopalan Google
May 07, 2014 | Proscan PS36700 36" TV
How to turn off closed caption?
Go to your TV menu and seek for "Closed Caption" menu. Select mode off (no mode 1, 2 etc). If you describe your TV model it will be more exact the help we can give you.
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: http://www.crutchfield.com/S-Kaec3gBqVtM/p_68326LA30Q/Proscan-26LA30Q.html . The direct link is http://a248.e.akamai.net/pix.crutchfield.com/Manuals/683/68326LA30Q.PDF .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
ProScan Model 40LC45S There is a black box in the middle of the screen only on one station. How do we make this go away?
This is a text box and is part of the closed captioning features your television has. You would have to turn closed caption off completely on your television. There should be a cc button on your television remote or in the television menu there should be a closed caption sub category you can go to and select off.
Jan 07, 2011 | Proscan Televison & Video
I keep gettting 'no CC info available' when I I hit the CC button on Proscan(26LB30QD) remote while watching cable. Cable box (DVR) is a Motorola DCX3400 and is provided by Comcast. I can do it from the...
You will not be able to get closed captioning by pressing the cc button on your television remote control. You must turn off the motorola cable box. Yes I did say turn off the motorola cable box. You should be standing in front of the cable box when you turn it off because as soon as it is turned off you must press the menu button on the cable box (not on the remote but on the cable box) right away. If you press menu soon enough after turning it off you will get a hidden menu. You will be able to scroll down to Closed Captioning and choose enable with the left or right arrow. Then just turn the cable box back on and you should have captions.
Dec 30, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Can't get closed caption
Press the menu button on the front panel of the tv or the remote control. Use the up and down arrows to find the features section.Press the right arrow to enter the sub-menu for the features section. Use the up and down arrows to find the closed caption section. Press the right arrow to enter the closed caption sub-menu.Used the up and down arrows and the enter button to go into each of the features, use the right and left arrows to adjust each control for you preferred viewing.Press enter again to select the feature in each of the controls.When you are satisfied with you selections press menu to exit the feature. This information can be found on the PROSCAN website in the customer section under manuals. Go to www.oncorpus.com.the information can be found on pages 21 and 24 of owners manual for your model television.I hope this information helps you with your problem.
Feb 08, 2009 | Proscan 32LA30Q Television
Black Box overlaid on image
Go into the menu and find "closed captions. Once there, turn off the "text" function. If you don't use closed captions, turn it all off. This will make your box go away. Let me know if I can be of further assistance
Jan 07, 2009 | Proscan PS27108 TV
Closed captions
Sep 02, 2008 | Proscan Televison & Video
Televison & Video Logo
145 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
