Question about Homelite ZR10926 16 Chain Saw
I have a Homelite PM-00376 chainsaw. It has recently been brought back from the dead by a friend after my father in law put it out of comission. I don't remember the fuel/oil mix ratio for this model. I was looking for a free manual download online with no success. Where can I find a manual for this model for free or cheap? Thanks in advance for any help!
  • 285 Answers
Fuel:Oil ratio is 25:1
Posted on Feb 14, 2011
Lost radio code for 2002 nissan pathfinder can you help please ?
Sorry to hear about your father-in-law. The only thing I can suggest is going to the Nissan dealership and have them put back the code
Good luck,
Marty
Jul 20, 2014 | 2002 Nissan Pathfinder
Tip
My father-in-law broke his him a couple of years ago and his son bought and...
For this tutorial, I will be addressing a common problem experienced by many Samsung LCD, flat panel TV owners these day... "My Samsung TV keeps clicking for 20 minutes before it comes on" or "When I press the power button on my Samsung, nothing happens" or "When I turn my Samung TV on, there are white dots on the screen" or "When I turn my Samsung TV on, there are multi-color vertical lines on the screen"... there may be more, but these are the most common I know of. The models are numerous and seem to stretch from 08' - 09'. If you are having this issue and want to fix it yourself, read on.
TOOLS: #2 Philips Screwdriver, Wire Cutters, Soldering Iron, Desolder wick (with Rosin), Rosin Core Solder, Replacement parts (will be determined after disassembly).
The first thing we need to do is unplug the TV and move it to a good work location. You will need a soft place to place the TV, perhaps on a carpeted floor or on a blanket placed over the kitchen table ;).
Remove the 4 screw for the stand (RED area) and then pull the TV off the stand and place the TV face down on you soft work surface. Remove the 4 large screws (GREEN area) and the rear cover screws (YELLOW areas). Now remove the rear cover (screw location may vary depending on your exact model, so please make sure have them all out first).
Depending on your model, you may have a metal shield covering the boards. If not, you can skim ahead...
There are 2 major boards that will be front and center inside your TV. On the left we have the SMPS... this is where we will be working. So, we need to remove the shield cover to get to it.
Now that we have the cover off, we are able to take a closer look and locate the faulty parts. Have a look at the upper right corner of the SMPS (Switch Mode Power Supply). You will see a cable going over to the main board on the right... in this area you will find the problem.
The faulty parts are capacitors. The tops are generally swollen and often have blackened material exposed or leaking from their bulging tops.
You will need to identify the electrical value of the parts and locate suitable replacement parts (try Radio Shack). The values may be 1000uF 10v, or 2200uF 10v... whatever they may, you replacement part have an identical uF value but a higher v value... ex: Original, 1000uF 10v -> Replacement, 1000uF 16v. This will help prevent this problem from reoccurring.
Once you have the replacement parts, you are all set to install them. So, unplug the connection on the SMPS and remove the screws from the board. Heat up that soldering iron and remove the capacitors. Use the Desolder wick to clean up the pads, this will allow you to insert the new capacitors with ease. Be careful, these parts have polarity. This means that they need to be installed the same way you removed them... positive to positive and negative to negative. Each capacitor has a negative terminal, each mount location has a negative hole and it is indicated by the wide black band. After you insert each part, fold the legs over on the solder side of the board so that the part does not fall out and stays in position. Once you have all the parts reinstalled, solder them in. Make sure you make a clean electrical connection. Now use your wire cutters to trim the excess legs. Be sure to trim them close so that they don't touch any other electrical connections on the board.
Your SMPS is now fixed and ready to go... reinstall it into the TV and connect the wire harnesses back up to the SMPS. Double check your work. Are all the connectors back in place? Ok, now you should test your work before putting the whole TV back together. Prepare the AC cord, use an extension cord if needed. You will need to flip the TV up on to its top edge (upside down, screen facing you). Plug the AC cord into the TV and press the power button. Do you see the Video/Input indicator or RF snow on the screen? If so, well done! If not, unplug the TV and check you work.
You are now ready to reassemble the TV and return it to service.
** If you need some assistance in the soldering area, please have a look at my Tip "Soldering on the kitchen table, Class 101". I cover the actual soldering of a capacitor in more detail there.
If you have found this helpful, spread the word and/or leave me some feedback.
on Jun 22, 2010 | Televison & Video
I brought a brand new homelite 33c-csp 3314 and my wife threw the manual out or i lost it ,how much chain and bar oil do you put in the oil part? i cant open pdfs cause somethings wrong with that thank...
Hi, basically you fill it up every time you fill up with two stroke fuel as it uses about 3/4 of a tank of bar oil to a tank of fuel. Regards Phil.
Aug 11, 2011 | Homelite Garden
I took my father in law's Remington 1.25hp
PRAY! NEVER BORROW a father in laws equipment!!!! Let it sit for a short time and cool down and then see if it will start. I would also check the air filter and make sure that it isn't plugged!
Jun 24, 2011 | Remington Garden
I'm getting a gas smell every time I light the unit. The unit lights and it works on all three heating levels but I keep smelling raw gas.
this sounds like your gas outlet test point is open if it was comissioned on original install the comissioner is to blame this also goes for service guy too as they should test appliance pressure on service and they do forget to seal it off, the funny thing is its gas its dangerous!so should never be left open. also i have had heaters get installed and had same problem before comissioning of heater as comissioning should be done by gas fitter as he would have found this and if has been comissioned he caused this, and look it may not be the reason why you are smelling gas but sounds more than likely to be it so call different gas fitter to come back and fix he won't tell you it's something its not and charge you for something you don't need to be charged for, you should then send his bill to original gas fitter to pay as he should have found this himself! its law for them to check the install and comission but they don't do it
Nov 15, 2010 | Procom ML300HGA Heater
I have a Medion Akoya which I recently brought from my Father in law. No problems connecting to his network. Now using my Netgear router I cannot get access to the Internet. Network is connected OK, just...
Once you plug it in, most the time you need to reset the modem and the router together, Unplug both let sit for 2 min then plug in the modem first then the router a couple seconds later. If your modem has a reset button, reset it!
Oct 17, 2009 | Computers & Internet
I am trying to find out the proper gas/oil mixture for a homelite chainsaw approximately 10 years old that was owned by my deceased father-in-law.
I would mix at 32:1. Most for the last several years recommend (by government intrusion) a ratio of 50:1 but that only serves to shorten the life of the equipment due to poor oiling & increased friction/wear. In spite of what many think, the lower ratio will not quickly foul the plug and it will extend the life of the unit.
Jun 29, 2009 | Homelite Garden
Homelite ZR10926 16 Chain Saw Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
