Question about Sharp Cell Phones
Nail polish remover has glued the 4 buttons on the right of the Sharp pv210 cell phone such that they do not depress. I've used a razor blade to try to break the bond from the outside to no avail. How do you remove the cover to get to the back of the buttons. I've removed the visible screws but don't want to force anything.
  • fdsele Oct 16, 2010
    Thanks for the reply but I really wanted to know how to take the cover off the cell phone so I can get to the back of the buttons to try freeing them from the glued bond. I guess I'm really looking for the manual for this phone which might show how to do this.
  • Sharp Master
  • 32,281 Answers
I'm afraid there is not much you can do. Trying to remove the nail polish with nail polish remover would be difficult and this could melt the plastic.
The face plate and buttons will need to be replaced.
It may be cheaper to upgrade your cell phone than repair it.
Posted on Oct 13, 2010
  • Chris Hingee
    Chris Hingee Oct 17, 2010
    After removing the back cover and the battery, most cell phones front face plate are clipped in placed. The face plate can be carefully levered off starting at the sides of the cell phone.
    If the face plate is secured by screws then, after removing the battery then remove the screws that secure the circuit board. When you remove the circuit board the keyboard can be accessed .
What product to use to remove Lacquer nail polish?
the product to remove nail polish is--acetone
it is available from chemists/hard ware /plumbing shops in small bottles and the directions for use should be carefully followed
Oct 09, 2015 | Air Tools & Compressors
HOW TO REMOVE CRAZY GLUE FORM ARBORITE
I would try either:
a) a razor blade and hot soapy water
b) acetone (nail polish remover)
c) if there is alot of it and neither of the previous 2 solutions worked, you can buy superglue solvent
Dec 14, 2012 | Elmer's Instant Krazy Glue
This is my problem:.. When the laborer put up our pharmacy... they put surgical tape on the glass doors.. and its been a long time to remove it.. I already used thinner but it don't help at all. I am...
HERE'S WHAT YOU'VE GOT TO DO:
There are just 4 simple steps that I can suggest for you to do:
1. Use any of the following solvents:
a. rubbing alcohol
b. acetone
c. nail polish remover
d. vegetable oil
e. olive oil
f. or, a Goo Gone
2. Soak a small piece of cloth to any of those solvents mentioned above.
3. Rub the cloth onto the surgical tape.
3. Use a razor blade to get rid of the tape totally. To make you safe, seek a scraper or holder of the razor blade so you won't get hurt.
4. Apply as much as solvent until the tape is totally removed.
I hope it fixes your problem. Thanks...
Jul 14, 2011 | Health & Beauty
Nokia N90 (year 2005)menu key sometimes does not function
DEAR FRIEND,
  1. 1ST OF ALL UNSCREW THE PHONE TO MENU BUTTON
  2. USE A SHARP OBJECT LIKE A RAZOR BLADE TO SCRATCH THE SURFACE
  3. TEST THE PHONE TO SEE IF IT WILL WORK
  4. IF AFTER TRYING THAT AND THE PROBLEM STILL OCCURS
  5. THEN YOU WILL HAVE TO CHANGE THE KEYPAD FLEX.
Feb 10, 2011 | Nokia N90 Cellular Phone
I have a chocolate touch and it says use genuine battery please help
Mine is doing this as well. I've also tried all the tricks-nail polish, rubbing alcohol, freezer...none of them have worked. I called verizon and of course they didn't help and said I'd need to get a new phone.
Aug 25, 2010 | LG VX8575 Cell Phone
The glass has come away from the outer hood at the
I have the same problem and read that in some cases 3M Wind-o-weld has been used to fix it. I tried that, and as soon as I put the top down and back up, it pulled back away. looks like I'll be getting a new top
Jul 20, 2010 | 2003 Audi A4 Cabriolet
I have a 2001 Grandam. My gear button kept
Use some "GOO GONE" ... probably the "safest" stuff to use to remove the glue.
Use Q-TIPS to apply and clean-up with a cloth, not paper towel.
Don't use nail polish remover or any acetone products, these will melt the button.
Don't use paint thinner either, for the same reason.
Sep 09, 2009 | 2001 Pontiac Grand Am SE
I cannot seem to add on my sharp el 2192 calculator just not getting my numbers printed
you may need an expert hand to do this:
open the case (4 screws at the back)
get the inner side of the buttons cleaned with nail polish remover/thinner.
after a while put all back.
power it on and check.
May 30, 2009 | Sharp EL-2192R Calculator
Melted plastic (teapot whistle) on glass cooktop
Hello. I don't know if this will work but you could try getting it as cold as you can and maybe it will come off that way. If it were me I would use my refrigerant, but I am sure you don't have that. Who knows maybe ice will work. Now that I think about it, maybe you can carefully use some sand paper being sure you don't scratch the surface.
Nov 28, 2008 | Jenn-Air JED8430 Electric Cooktop
Change Faulty/Cracked touchscreen on P900
The screen consist of two parts: touchscreen(TS) itself and LCD screen. They're attached mechanically, not with glue or solder.
TS glued to metal frame and by mean of this frame(mechanically) attached to LCD(like shoebox cover) - you can see pits on side.
1. With sharp blade of razor or scalpel gently remove this frame with TS glued on top.
2. Then remove TS from the frame (I simply broke it and removed glass pieces from the frame)
3. Clean the frame with alcohol to remove glue and grains of glass.
4. Glue new TS to the frame at ONE SITTING!
5. Wipe out dust from LCD and inner surface of TS and attach the frame.
6. Buy conducting glue and connect 4-contacts of TS cable with LCD cable. Put adhesive tape over them to maintain electric connection.
That's all.
Jan 28, 2008 | Sony Ericsson P900
Cell Phones Logo
20 people viewed this question
Top Sharp Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Daniel Dollive
Daniel Dollive
ismael castillo
Are you a Sharp Cell Phone Expert? Answer questions, earn points and help others
