Question about Samsung SyncMaster 172N 17" LCD Monitor
Samsung screen goes black, comes back on and graphics are scrambled
Hi everyone, i know there are a number of questions regarding monitors going black but i have not found a solution to mine.
I am running windows xp sp2 and have a 17 in Samsung syncmaster 172n as my primary monitor running to my brand new galaxy 8600gt video card via the vga port, i am running my hitachi 32inch lcd tv as a secondary monitor (eg, extend windows desktop), the tv is connected via vga but through the dvi port via an adaptor. The issue i am having is that while i am working on my pc using the small lcd the screen will go black at random times (especially when i am doing a number of things) then come back on, this is annoying enough but sometimes when it comes back on the graphics are all scrambled, sometimes if i leave it for a minute it corrects itself, others i have to disconnect the vga and plug it back in but even then i may need to do it three or four times to correct itself.
My mother board is a Gigabyte GA-81945P-G-RH and i experienced this problem on my previous gigabyte video card (hence why i bought the galaxy) but i am still having the same problem.
Any help would be greatly appreciated.
  • 1 more comment
  • anilfabian18 Jun 29, 2008
    My LCD Samsung SyncMaster 730BF screen always flickers and some times it turns off and comes back again.
  • paulkni Aug 29, 2008
    I have had the exact same problem. Not only with my 172N on winXP, but also my friend has the same setup and the same problem. The I have removed the Samsung driver and used the windows driver with the same result. The problem appears to get worse the longer the monitor is running.
  • Anonymous Oct 12, 2008
    After system is on about an hour or so monitor begins to turn black and then flash back on. It gets worse the longer I stay on the computer.
Check for defective and leaking electrolitic capacitors
Posted on Oct 30, 2008
How do I fix an occasional black screen on a Samsung LN46B630?
Sounds like T'Con board fault. For some models of Samsung LCD TVs, this part is built in the panel, means non-replaceable. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 20, 2015 | Samsung LN46B630 LCD TV
Toshiba satellite monitor is scrambled, how to fix?
Check to see if the problem is the screen Inverter, or the graphics chipset, or the LCD screen.
Use an external monitor as a test.
If the screen of the external monitor shows a scrambled display you have a problem with the graphics chipset.
If the screen of the external monitor does Not show a scrambled display, you have a problem with the screen Inverter, or the LCD screen.
90 PERCENT of the time the fault is the screen Inverter.
External Monitor;
1) You can use a CRT monitor, (Looks like a small TV), as a VGA monitor,
Or
2) You can use a flat LCD screen monitor that has a VGA cable.
A) Laptop OFF, and monitor OFF, attach the VGA cable from the External monitor, to the VGA port on the Toshiba Satellite A205 series Notebook PC.
This is an example of a VGA cable, and it's connector, and a VGA connector on the laptop,
http://en.wikipedia.org/wiki/VGA_connector
B) Turn the monitor on. If it is a CRT style let it 'warm up'.
Turn the laptop on.
C) The display is supposed to automatically show up on the external monitor.
If it does not, press, and hold down on the Fn key, and also press the F5 key.
Still no?
Holding the Fn key down, tap the F5 key again.
Display good on external monitor? Problem lies with the screen Inverter, or the LCD screen.
Either OR.
Primer:
An LCD screen does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
An Inverter (screen Inverter) is used to convert the electricity provided by the laptop, for the LCD screen, and Backlight.
As previously stated, 90 PERCENT of the time the fault is the Inverter.
Laptop open looking at the display assembly, the plastic thin frame in front of the LCD screen, and surrounds the LCD screen, is the Display Bezel. (Resembles a picture frame)
The Display Bezel is removed to access the screen Inverter.
The Inverter is right behind the Display Bezel, and located at the bottom area of the LCD screen.
The Display Assembly has to be removed from the laptop, to remove the Display Bezel.
Toshiba's term for the Display Bezel is Display Mask.
The Toshiba Satellite A205-S5804 Notebook PC is one of the Satellite A205 series of Notebook PC's.
This is a link to a free Service Manual for a the Satellite A205 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down to the second Satellite heading. The one that begins with Satellite A10.
Scroll across, and click on A200.
After you click on A200 it may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
Go to Page 146.
4.10 Display Assembly
Page 151 shows how to remove the Display Mask.
4.11 Display Mask
Page 153 deals with the screen Inverter.
4.12 FL Inverter Board
Takes a really sensitive (Read fairly expensive) multimeter to test an Inverter.
Due to the low price, and ease of replacing, the screen Inverter is replaced to test whether the old one is bad.
Example of a screen Inverter (FL Inverter Board) for a Satellite A205-S5804 Notebook PC,
http://www.batterysupport.com/toshiba-satellite-a205-s5804-inverter-p-216526.html
Compare to the price of a replacement LCD screen,
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~A205-S5804/
To summarize so far;
1) Display shows good on external monitor. Replace screen Inverter. Still the same problem? Replace the LCD screen.
2) Display on external monitor is scrambled also?
Fault lies with the graphics chipset.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The graphics chipset is a GPU.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
The GPU for a Toshiba Satellite A205-S5804 Notebook PC (Part Number PSAF3U-0NR00V), is an Intel (Mobile) GL960 Express,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_mobile_chipsets
It is soldered directly to the motherboard, therefore it is Integrated Graphics.
{Integrated Graphics is also known as OnBoard graphics.
ON the motherBOARD.
The GPU is soldered to the motherboard.
In comparison if the GPU were soldered to a removable adapter card, it would be a graphics card, and Not integrated graphics }
This means if the graphics chipset is found to be bad, motherboard replacement is the solution.
{ Disassembly guide,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm }
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 05, 2011 | Toshiba Satellite A205-S5804 Notebook
Hi, I just received a new Dell monitor model number PP32LB. The first time I plugged it in it prompted to either be dual screen or just monitor, and now my laptop automatically goes to just monitor and...
remove the extra monitor from the laptop, turn it off then back on, it should work normally, once its back on and normal you can change the graphics settings
Sep 18, 2010 | Dell Computers & Internet
Dell F171FPb flat panel color monitor
wunder558, Check the back of the monitor for correct model number and DOM. Is it an E171FPD ? Could be bad (failed) "lay on floor or internal "switch-mode-power-supply" !! This unit could be 5 - 6 years old!!! Have you checked cost of new same screen size lately? What is approx total "ON" hours unit has seen during it's lifetime? Are all connections (cables) still tight? If you are technicially inclined, visit some sites that deal with refurbishing LCD monitors with new "cold-cathode-fluorescent-lamps" and "inverter" power supplies that light them up. Do some reading in my FIXYA profile to understand the technology you are dealing with. The technology behind your monitor NO DIFFERENT than any other CCFL back-lit LCD monitor. Come back to fixya to let us and everyone else know what you decide to do about your black or black and blank lcd monitor. 12fixlouie All the information you need to make decision can be found on FIXYA.
Feb 09, 2010 | Computers & Internet
When I power up my PC and monitor, the screen comes on for a couple of seconds, then it goes black
this happens with a few monitors and some graphics cards. if you connect your monitor through a DVI cable, try connecting it through an analog cable. if possible change your graphics card, that should solve it completely.
Jul 01, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Al2416w acer monitor comes on says acer then goes black
dose the standby button go orange, if it dose then the screen is going back in to standy, its possible that your graphics card is having problems, maybe if you put some more informationt about what happens then you could get better help.
Mar 17, 2009 | Acer Al2416WD LCD Monitor
Samsung 172N 17" LCD monitor blacks out seconds at a time with increasing frequency and eventually displays scrambled graphics until system restart.
The problem I have is that when we connect the screen it wiorks fine then blacks out after 5-40min
It then flickers on and off iregularly and every now and then shows distortion and eventually just blacks out
I have two 172N monitors and both now show the same symptoms
We have used different VGA cables and different computers in different locations all with the same result
There is no external influence that we know
Oct 30, 2008 | Samsung SyncMaster 172N 17" LCD Monitor
Monitor pixelates and goes black
video card most likely...do you have an external monitor to try it out on, to be certain?
Feb 16, 2008 | Sony VAIO VGN-S460 Notebook
Monitor problem: screen goes black, then comes in scrambled
It sounds like this one needs component-level troubleshooting, probably in the power supply section. One or more backlights may be going out, too.
Dec 31, 2006 | View and View Technologies VNV AquaView...
Samsung SyncMaster 172N 17" LCD Monitor Logo
677 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
