Question about Whirlpool Duet GHW9150P Front Load Washer
It seems to get stuck on the rinse cycle and flashes F and H then stops. Any ideas
    Sergeant:
    Champion:
  • 351 Answers
Hi FHis code for no water. i would check the water valve at the back of washer pull hoses off check the screen inside of valve. most likely the cold side is stopped up jim
Posted on Oct 14, 2010
When washer done rinse cycle lights flash and washer stops doesn't rinse and spin
Hello
Try reseting the machine.Unplug power for 60 seconds.
Plug back in,then turn knob to reset.Then try another load of wash or finish the one that is stuck before rince cycle.
It is possible the control timer is going bad.
Aug 29, 2010 | GE Washing Machines
My dishwasher is starting it's cycle, then running for a minute or 2, then it stops and drains itself, then starts the cycle over and repeats this. It won't continue it's cycle and it seems to be stuck in...
you seem to be stuck in a 'quick rinse' cycle. double check your buttons as well as your timer/dial to see if you are using the normal wash cycle. especially check the buttons. good luck
Nov 02, 2009 | Frigidaire Dishwashers
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Dishwasher drain issue
check to see if there is anything stuck in the drain pump. it not, replace the drain pump, as it's malfunctioning.
Sep 13, 2008 | Dishwashers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
My machine was stuck on rinse cycle now on ventilate...
Try first to continue filling up the water resovoir (UP TO FOUR times) to see if the machine completes the rinse cycle on its own. If that doesn't work contact Gaggia Customer Service in the US at 888-389-4123. Sally there was VERY helpful and should be able to resolve your problem.
Dec 31, 2006 | Gaggia Titanium Espresso Machine
Whirlpool Duet GHW9150P Front Load Washer Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
