Question about Homedics Automatic Arm Blood Pressure Monitor ()
Cuff leaks-model pp-bpcuff2,What can be done?
What does Er 4 mean on my cvs blood pressure machine
YOU did NOT SPECIFY your MODEL NUMBER but tonight ~ Christmas Eve ~ YOU got LUCKY! I found this and it may help you... but
THIS INFORMATION MAY NOT BE FOR YOUR DEVICE!
"LCD shows "Er 4"
Pneumatic system leak
or cuff is too loose during inflation
And this:
LCD shows "Er 0"
Pressure system is instable before measurement
Be still and measure again
LCD shows "Er 1"
Systolic pressure detect fail
LCD shows Er2 Diastolic pressure detect fail
LCD shows "Er 3"
Pneumatic system is
blocked or cuff is too
tight during inflation
Place the cuff correctly
and try again
LCD shows "Er 4"
or cuff is too loose du-
ring inflation
LCD shows "Er 5"
Inflation
above
300mmHg
Measure again after 5
minutes. If the moni-
tor is still abnormal,
please contact the
local distributor / ma-
nufacturer.
LCD shows "Er 6"
Over 3 minutes while
pressure above 15
mmHg
LCD shows "Er7"
EEPROM accessing er-
ror
LCD twinkling
Device
parameter
check error
LCD shows "Er 9"
MCU self-verity error
LCD shows "Er A"
Span error
LCD shows "Er b"
EEPROM Backup-error
http://webcache.googleusercontent.com/search?q=cache:V0KPe0jswmgJ:www.hmm.info/uploads/tx_sbdownloader/smartLAB_profi_user_manual_ENGLISCH_R4.pdf+&cd=2&hl=en&ct=clnk&gl=us&client=firefox-b-1
Dec 21, 2017 | Health & Beauty
I need to order the arm cuff for model 1086CVS
What you show is a model number for a B/P cuff that is not one
shown for CVS. You also do not mention a size for the needed cuff.
Cuffs come in different sizes from Infant, Pediatric, Small Adult, Adult, Large Adult, Thigh.
CVS, and all the different manufacturers sell cuffs to fit monitors. Only the size of the cuff needed matters, and possibly the end fitting if something more is used other than just the rubber hose.
Look up any online company, or your local pharmacy and look for the replacement cuffs for monitors.
Apr 19, 2017 | The Health & Beauty
Dear sir/madam , i have an blood pressure monitor with this model;SBM 07 but when i want to take my blood pressure it is showing error and not going up just going 45 how i can solve this problem and ,
Look fo leak in tubing or cuff. Probably pinhole in cuff (watches or rings and stuff can puncture it sometimes).
put the tubing under water and pump up, looking for bubbles... My suggestion. If no bubbles, pump one-way valve is probably failing or has a dirt all stuck in it holding it open and so leaking to cause not pumping correctly.
Oct 19, 2014 | Health & Beauty
My model bm35 wont hold air
Check cuff and hoses for leaks.. Submerge cuff and hoses in water and pump up looking for bubbles. Bubbles=hole.
Oct 15, 2014 | Health & Beauty
My blood pressure machine starts then stops and restarts quite a few times
It sounds as if there's a leak somewhere in the system. Make sure all the lines are well-connected, and that the cuff isn't leaking.
Jul 10, 2011 | Sunbeam DIgital Blood Pressure Monitor...
SOFTWARE PROBLEM DURING PUMP FUNCNTION SO MANY ERROR I WANT UREGENT SERVICE PLESE CONTACT NO. & ADD. SERVICE CENTER IN AHMEDABAD
What brand of BP Monitor?
Is this a personal BP monitor?
Or is it a hospital BP monitor?
Well.. you have to check the cuff to see if it's OK. Most of the errors are because of the cuff which has a balloon inside the cuff.
It depends on your model.
On some models you can take off the cuff line. Check if there is air coming out from the BP machine. If there ir air, it must be probably the cuff.
If both the cuff and machine is OK, then the problem must be the machine calibration.
Is it electronic or manual BP?
Hope it helped.
God Bless You!
Feb 05, 2011 | Health & Beauty
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Cuff won't inflate
It probably has a leak. Examine the hose and cuff for cracks by flexing it , especially at the fitting where the hose attaches to the monitor. Also check where the hose attaches to the cuff. Try replacing the cuff.
Hope it helps. Please let me know.
Thanks
Apr 22, 2010 | Mabis Automatic Digital Blood Pressure...
My Braun BP meter (model 6071) will not hold pressure in the cuff. It appears to be leaking. Can I replace this ? Where are the parts able to be sourced from? I live in Australia but bought this item from...
In my experience as a nurse the major points of leakage are at the junctures near where end of tubing is. The way I have fixed both my own and my hospitals cuffs is to identify where the leak is occuring and if it is in the tubing disconnect at that point and use scissors to cut off the leaky part of tubing at the point of tubing leak and reconnect careful to take only enough off to sever leaky part. If the leakage is in a valve I cannot help you but the vast majority of leaks are in the rubber tubing
Jun 20, 2009 | Braun Health & Beauty
Homedics Automatic Arm Blood Pressure Monitor () Logo
110 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
