Question about General Electric WCVH6800J Front Load Washer
Have a GE Model WCVH6800J1MR that doesn't fill with water. It appears to start and spin when the soap would go in, but no water. Checked water supply is fine. Checked for kinked hoses they are also fine. Had a repairman out and he said replace the door lock. Ordered the part spent the extra money to have it 2nd day delivery. Installed the new part and still not filling with water. Currently out the $85.15 for the home call and $160 for the part. Called GE and they said they would sent the repairman back out. Not sure he knows what he is doing. Any suggestions?
    Scholar:
  • 44 Answers
Cool thing about these new computer controlled appliances is that they diagnose themselves. Easiest way to find issues is to run a diagnostic test: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Post back once you have the codes and we'll see about next steps.
In addition to t02, you should definitely do "t08" and "t09" tests to check the hot/cold water valves. Have a GE Model WCVH6800J1MR that doesn't fill - chris_in_ma_7.jpg
chris_in_maHave a GE Model WCVH6800J1MR that doesn't fill - chris_in_ma_9.jpgmi
Posted on Jul 28, 2011
I have a GE washer model wwse3160a. It does not function except it fills with water. I checked the drive belt, I tried turning the motor clockwise and it spins the drum. All the lights come on but it...
Hello
I am familiar with this problem and 99% of the time it is caused by the washer lid safety switch, if the switch doesn't function the washer control will not let the cycle run past filling the tub with water. You can buy the part and get information on how to install it from a company called www.repairclinic.com
Sep 14, 2011 | GE WWRE6260D Top Load Washer
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Recently glasses started to finish foggy and
MOST OF THE TIME "FOGGY GLASS" IS A RESULT OF SOAP BUILD UO IN THE DISHWASHER. IF YOU HAVE A WATER SOFTENER AND FILL THE SOAP CUP ALL THE WAY THEN THIS IS THE CASE. FILL A COFFEE CUP WITH WHITE VINEGAR AND PLACE IT ON THE UPPER RACK, RUN AN EMPTY LOAD ON HEAVY DUTY WASH, THIS WILL STOP THE PROBLEM, YOU MIGHT NEED TO REPEAT IT 2-3 TIMES BUT IT WILL WORK, AFTER THAT JUST USE AS LITTLE SOAP AS YOU CAN, IN MY GE I USE POWDERED CASCADE BUT ONLY FILL THE SOAP CUO TO THE BOTTOM LINE, WORKS GREAT. GOOD LUCK
Jun 10, 2010 | GE Nautilus 24" Built-in Dishwasher
Wont fill or spin runs dry
Check the water pressure switch for proper operation
Oct 19, 2009 | GE WBSE3120B Top Load Washer
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
Ge front load washer model WSXH208A Will not spin
Mine kept stopping mid cycle also, pouring water on the floor, then the start/pause button flashed and the door unlocked. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Oct 13, 2008 | GE WSXH208A Front Load Washer
Spin cycle not working
try the door switch the washer will do everything but spin if the door switch is faulty
Jul 13, 2008 | GE Profile WPSR3120WWW
General Electric WCVH6800J Front Load Washer Logo
856 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
