I have a kenmore top loading washer (MODEL # 110.28882790). Recently is stopped spinning with with larger loads. It will spin if it is less than a third full. Anything over a half a load and it will not spin at all. Looking to find out the problem.
  • 1 more comment
  • David Reis Oct 14, 2010
    Thanks. What is the best sequence to dismantle the washer to get at the belt. This is a first for me and would appreciate any input on replacing the belt.
    Can you give me instructions on the easiest way to get to the belt
  • David Reis Oct 18, 2010
    It sounds like this is the problem. I will do further follow up
  • 347 Answers
If you have a Whirlpool or Kenmore direct-drive washer with a weak or lazy spin which gets worse with a heavier load, it may have a bad clutch or transmission Chances are the clutch is just slipping the only concern is if the trans is leaking oil thats getting on the clutch causing is to slip. If you tilt the unit back you can look inside the cabinet if you see oil slung around the inside trans is leaking if not you just have a worn out clutch
Posted on Oct 14, 2010
    President:
  • 1,554 Answers
Your machine is direct-drive therefore it doesn't use a belt. The motor is directly coupled to the transmission by means of a coupler not a belt. The problem is in the clutch assembly.The clutch band has a tab that pushes the brake cam driver to release the brakes and allow the basket to spin. If the clutch lining is worn or the clutch spring is weak, the friction between the clutch hub and the lining is not enough to drive a large load.
Posted on Oct 15, 2010
    President:
  • Washing Mach... Master
  • 1,932 Answers
The drum doesn't spin in large loads because the belt driving the drum may be lose.Due to which the belt slips off and the drum doesn't spins.Change the correct belt size and it will be fine
thank You
  • Udhaya Rajan
    Udhaya Rajan Oct 15, 2010
    Sorry for the late reply.This machine is not a belt driven.It is a clutch mechanism.I suggest you to get for a service .Because repair of clutch mechanism is complicated
    Thank You
Top loader series 80 Kenmore doesn't stop after the whole wash cycle, it goes directly to 2nd rinse, then spins again and stops?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Since it does everything else, the problem points to the timer.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers with an extensive troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't always spin on its own
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Since it will spin on lighter loads, the problem points to the clutch.
When the washer goes into spin mode, the motor is reversed to spin the pump and a clutch on top of the transmission engages to spin the tub.
Following is a description of how to access the clutch and check the clutch bands.
Sears and Whirlpool have a replacement parts kit for the clutch.
If the bands look OK, the problem could be in the neutral drain inside the transmission.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Oct 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 washing machine does not spin or agitate
make sure your pump is not clogged or jammed..that will stop the motor,,quick test,,pull pump off and start unit in wash,,or spin if unit is empty..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
