Question about Pioneer PRO-630HD 58" Rear Projection Television
Pro630HD standby flashing red. need reset code
  • connor8084 Oct 14, 2010
    yes there is a code i had a serivce man give it to me once before
    i dont remember the code but it was something like (return, menu, select, power) pressed in to the front of the tv. do you know any codes like this
  • Pioneer Master
  • 12,061 Answers
Http://www.tradebit.com/filedetail.php/3181290-repair-manual-pioneer-pro-730hd-pro
Hi please find above a link for your service and repair manual, you MUST use one of these to even begin to have a shot at a repair.
This is a fairly classic switchmode power supply, there is a fault within the set, that is so bad, and this has been detected by the SMPSU, which is then shutting down the set to avoid a fire, explosion, or both. This set has developed a problem, that is so severe that the set must be shut down immediately, and all power except for standby, and if severe enough, then even that will cut off too. This set should now, be totally removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Pioneer, in your case. Now, when you get the information you want, take it to, or get them to call, either way, always get from the repairer a "Quote" first, before proceeding with any repairs. Then at least, you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have original parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
However, If you really want to have a go and try to repair your set, well OK. But PLEASE, start in the right place, otherwise you will simply waste your time and money, You see, you MUST start, in the right place, The power supply, FIRST, as, if, that isn't right, nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now, also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" and replace them, because someone else had done so and it worked, well that maybe sometimes true, but most Symptoms, can, and do have many, many different "Causes" & also, now while that may be true in a few cases, a faulty Electrolytic Cap, or even, ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins.
Posted on Oct 14, 2010
  • Pioneer Master
  • 5,138 Answers
I dont think a reset code is goig to help this problem . You need to check on the power supply board and in the Middle is a 6.3amp Fuse CK to see if it is blowed, If OK Then check all the pico fuses they will look like resistors but will be either Green or Yellow 5amp,6amp,7amp fuses
They if they are good STK ICs mighht need to be replaced STK392-110s 2 of them .
Mats Electronics has all of these Parts 1-800-628-1118
Posted on Oct 13, 2010
  • ladywinn
    ladywinn Oct 14, 2010
    What Year is this TV? What is the Model# Printed on Back?
Sony Bravia showing 4 red blinks any idea what this means, fault?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 27, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The standby indicator is flashing 4 times on my sony bravia KDL55nx720 tv and will not start. Is there something that needs to be reset?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Aug 09, 2014 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
KDF-60XBR950 Red light blinks 5 times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 01, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic viera 42" UT50Z What do 3 red flashes on standby light mean for trobleshooting
Three flashes of standby light denotes a fault to SOS D-board. If you wish to get more details about this fault, check the link sited below. Blinking codes http://electronicshelponline.blogspot.com/ many brand TVs are given in detail. Pull up older posts there by its left sidebar.
Jun 16, 2013 | Televison & Video
Tv not coming on is on flashing standby red light
How many times do the standby light flashes at a time? Count this. These flashes are fault indications. Check this to know more about blinking codes to Panasonic LCD and Plasma displays.
Jan 03, 2013 | Televison & Video
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
Oct 17, 2010 | Sony KDL-46XBR4 46 in. LCD Television
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Flashing red standby led code 11
I am sure you know that is a code for service. Was there a pop or anything when the problem started? I would say bring it in for service.
May 11, 2008 | Pioneer PDP-5070HD 50 in. Plasma...
Pioneer PRO-630HD 58" Rear Projection Television Logo
213 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
