Question about Kodak EasyShare DX6490 Digital Camera
Zoom feature lately...when i use the zoom feature...it's doesn't stay focused. it keeps moving in and out of focus when i'm trying to take a picture.
Could be the battery is old and not charging well. Happened to mine & once I got the new battery everything was fine again!
Posted on Jun 20, 2008
Focus on Ricoh R6
Could be that the electrical connector on the autofocus has come off. This is a job for a repairer.
Mar 21, 2012 | Ricoh Caplio R6 Digital Camera
The lens keeps trying to focus it zooms in and
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dec 02, 2009 | Nikon Cameras
Camera won't focus when using optical zoom
I had same problem. Found that doing a complete reset fixed it. Go into setup and at end there is a factory reset. If not working after that would suspect your ccd sensor is on way out. They should last 5-7 yrs. Be cheaper to get another cam with way prices have come down
Jan 08, 2009 | Fuji FinePix S5000 Digital Camera
How do you go from zoom to macro?
From my experience, many zoom lenses that have a macro feature simply kicks into macro mode when the lens is in fully zoomed position. Remember, macro is used to take pictures of something (usually like a flower, insect, etc.) and to magnify it several or many times larger than it really it is. And as a result the subject is huge and sharply focused with a very blurry background. Another thing to keep in mind is that there is usually a focusing limit for the lens in terms of how close one can focus a subject in MACRO zoom mode. In other words, you (the lens) may have to be at least a foot or more away from the subject in order to automatically focus sharply. On this note, if you have manual focusing capability, you should be able to take pictures in macro zoom mode from even shorter distance from the subject, resulting in more larger than life pictures!
I Can Fix it
Sep 03, 2008 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
No picture and lens does not retract
Well some cameras has features that does not use the LCD screen of the camera, because to save battery power or to get better shots with the focus ring.
You can just use the area where you focus your eye to aim and shoot the object of image.
Try to enabled the LCD screen feature.
The Zoom Lens Wiggles 3 times because it is programmed to zoom at the standard zoom size, this is totaly normal for camera in digital and analog types.
Mar 05, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
H1 out of focus above 7xzoom?
HI, are you sure that there is no conversion lens setting activated in the setup menu? It sounds like that to me. These modes limit the ranges. I hope it will help, otherwise you will have to bring it back.
Sep 12, 2005 | Sony Cyber-Shot DSC-H1 Digital Camera
Cannot focus on a particular subject
If the camera is having a difficult time auto-focusing, you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance from you and then move the camera back to the intended subject and take the picture without losing focus. First, turn the camera on and locate the Autofocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away as the subject the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While holding the shutter button halfway down, aim the camera at the original subject and press the shutter button all the way down.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Focusing distance in macro mode
On a D-580 Zoom camera, the Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympia OL-5805 Cordless Phone
Focus on a particular subject
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamplights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Focus on a particular subject?
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 42 in the D-535 Zoom Reference Manual in Section 3, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation.)
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Kodak EasyShare DX6490 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
