Canon mp600 printer, there is no indication of power coming to printer. No lights nothing. It's plugged into a confirmed power source.
  • 144 Answers
Check the power is coming out of the the power supply connector usually between 12-16V
Posted on Oct 13, 2010
Canon MP600 printer not printing correctly
The cleaning sponges are on a spingy pad, which can get stuck because of the old ink get a bit gunky. This can cause error 5101.
Try this...
Open the bonnet, use a torch, gently tug the ink carriage to the left of the rails.
Clear any paper jammed in the right of the ink carriage.
Lightly press the cleaning sponges down, (I used a long pen)
Restart the printer.
Jan 12, 2012 | Canon PIXMA MP600 all-In-One InkJet...
Cannon MP600 printer shut itself down during printing operation . Pressing ON/OFF button will not turn it. I checked connections and power source. Still, no reaction.
Re: "Cannon MP600 printer shut itself down during printing operation ."
If a Canon inkjet printer is turning itself off, then problem is either control board or power unit. When this happens printer is often considered beyond repair, and in any case it must be tested by a technician to find out the problem.Repair involves testing volts out from power unit and testing components on main board.
Considering that the MP600 is quite an expensive inkjet, I suggest contacting Canon support and asking a quote on repair.
Here Canon support pages:
Canon U.S.A. : Contact Us
Canon U.S.A. : Support
Canon UK - Support
Canon South Africa - Support
Aug 30, 2010 | Canon Office Equipment & Supplies
Install the correct print head
You can clear the errors in your printer in three reset procedures.
Reset it manually
1. Turn off the printer
2. Press and hold the Resume Button, an indicator light green
3. Press and hold the Power button
4. While holding the Power button, release the Resume button
5. While holding the Power button, press the Resume button twice
6. Release the Power button
7. Press the Resume buttons four times
8. Press the Power button to confirm the operation
9. Turn off the printer
Reset canon mp600 to factory setting (if the first procedure did not work)
1. Press the Home button
2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press OK button.
4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset Settings, then press the OK button.
5. Use the Easy-Scroll Wheel or the up/down arrow to select Yes on the confirmation screen and then press OK
6. Press the HOME button to return to the Home Menu
Final reset (If errors did not clear and or another error appears this will clear it)
1. Press and Hold the Resume button and wait until the printer self restart.
2. Release the Resume button when the printer restart
3. Wait until the printer fully initialize and try printing again.
That will solve it.
Please comeback and give some ratings.
thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Wat's mean E16
E16 -E19 = Failed to scan head alignment sheet
www.youtube.com/watch?v=XyT6JsD0o88
Resetting Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970 procedure:
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
http://thamrindsa.wordpress.com/
May 27, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
How do you scan 120 negs?
The MP600 cannot scan film or slides. Film/slide scanners need a light source to shine through the film to the scanner sensor. You can use a flat bed scanner with a light source such as the CanoScan 5600F, or a multifunction unit equipped with a backlight source such as the Canon PIXMA MP810, MP970 or MP980.
May 19, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP145 blinking power LED and alarm LED.Displays E...2....7.please assist me
E27 means waste ink absorbed is full need to clear out but you still can't print because only 80% or 70% are full.try this method to solve you problem.
•Turn off the canon printer
•Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
•Hold the Power Button, release the Resume Button.•Not releasing the Power Button, double click “Resume” and release Both Buttons.after that wait the green flash will become light on then.
•Click “Resume” for Four times
•Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
if this ok so u can print or can't. i still suggestion you bring you printer to computer shop for clear out inside spam printer.
Aug 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer went off. Lost power and won't turn back on.
Try "reinitializing" the device (printer):
  1. Shut down the computer system the printer is connected to.
  2. Unplug the printer power cord from both the printer and its power outlet.
  3. Wait at least 5-10 minutes, then re-plug both ends back in.
  4. Switch on the power button to the printer (if no indicator light is on).
  5. Restart (reboot) system.
Also, you can also rule out it being a failed power outlet by trying a different one to plug the printer into.
Good luck, and please post back to let me know how things work out, or if you have any further questions.
"Today's the best day of my life...and NOW you're part of it!"
Dec 21, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Mp530 check ink alarm won't go off with reset button- want to bypass alarms.
Reset Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970
  2. Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  3. Hold the Power Button, release the Resume Button.
  4. Not releasing the Power Button, double click “Resume” and release Both Buttons.
  5. Click “Resume” for Four times
  6. Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 14, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP 600 Will Not Turn On .... grumble.
I had this same issue. Lost power in the house for just a second, but after the printer would not turn on. I think that the loss of power caused the printer to get stuck in a locked state. Tried everything I could think of including changing outlets that the printer was plugged into but nothing seemed to work. Saw a troubleshooting tip on the Canon webpage about unplugging the unit for 5 minutes and thought it was hooey, but tried it anyway. Ended up leaving the unit unplugged for probably 15 minutes and when I re-plugged it in it fired right up.
Oct 09, 2007 | Canon PIXMA MP600 all-In-One InkJet...
55 people viewed this question
k24674
jasbo
jasbo
