Question about Lexmark X2600 InkJet Printer
Lexmark printer 3600-4600, after paper jamed and took paper out . but it still shows " paper jam " all the time . And printer seems not remove "paper jam" away even reconect box jection behind ...etc. It seems happen quite often , and disconnect the power or connection box and will starts again , but not this time ? WHAt should I do to make back to normal ?
  • 144 Answers
Check that their is no pieces of paper broken off in machine and that all the paper sensors are not still jammed and moving freely then switch off machine for at least 30sec then switch on should work if not check again and make certain all covers and doors are properly closed
Posted on Oct 13, 2010
Had message paper jamed pulled out paper now cant get the power to come on
Disconnect the printer from the power supply for 30 seconds, connect again to see if work. Make sure you remove the jam paper completely.
Apr 30, 2011 | Lexmark X3470 All-In-One InkJet Printer
IF PAPER HAS NOT JAMED BUT MACHINE ARE SHOW PAPER JAMED
Try cleaning the rubber paper feed rollers. If it fails to pick up the paper in a pre determined time it will show paper jam. The pick up tires must pick up paper when turning, if not the paper will not feed into the machine and it will show paper jam with no jammed paper.
Mar 16, 2011 | Canon imageRUNNER 400S Copier
The paper jam button is on, but there doens't seem to be any paper in there. I took the paper tray out and examined the underside of the printer, no visible paper jammed. I undid the back access part,...
power off printer
remove paper tray
open front panel
remove both tonor and phto conductor kit (tonor seats inside of that)
inspect inside the printer
Chances are there is a fragment of paper in the right corner near the paper sensor
replace components
restart printer
Keep me posted
Feb 01, 2010 | Lexmark E232 Laser Printer
The problem is a paper jam
If it says there is a paper jam and there is no paper jamed. Then try opening and closing any compartments on the printer, this resets faults like a "paper Jam".
Sep 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Can't see Paper jam
Open the top cover to see the jammed paper. If u wont see the paper then you have to open the cabinet of the printer . After opening remove the paper
cheers
Jun 23, 2009 | Lexmark X2470 All-In-One InkJet Printer
Paper jam
I had that problem quite a few times. i had to reset power to my computer and the printer on each occasion. seems to reset itself from there.
Jun 11, 2009 | Lexmark X73 All-In-One InkJet Printer
PAPER JAM IN MY LEMAX X4650
Have you really checked the printer, there may be a small piece of paper jamed inside the printer, this is a common fault and common fix for most printers.
Jun 03, 2009 | Lexmark X4650 InkJet Printer
Lexmark x342n all-in-one printer paper jam
Is any part of the page imaged?
What is happening is that a paper sensor is either hung or jamed so that the sensor is incorectly reporting an error .
I would remove the cartridge and using a flash light search for any scrap of paper that may be in the paper path. If you can't find any, I would next looked for a sensor flag to see if it is jammed out of position.
Of course, you could always call a service tech or even better submit this question to Lexmark Technical Support for more in depth assistance.
May 31, 2009 | Lexmark X342n All-In-One Laser Printer
Frequent jam in Lexmark E232
This can happen a lot if you're using very light weight paper.  Also, if the paper is not flat it can jam up too.  Best thing you can do is get yourself some higher quality paper and keep it in a air tight tub after you open it.
Nov 22, 2008 | Lexmark E232 Laser Printer
Paper jam
hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Mar 02, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X2600 InkJet Printer Logo
403 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
