Question about Ford Vehicle Parts & Accessories
2000 ford excursion 4x4 7.3l diesel, can not start, get in truck, put key in ignition, sounds like it has electric power ok- then all dead when turning key to start, diconnected battery and hooked it back up still not starts, charged battery still same issue-theft system seems to prevent starting...any help? thank you and yes it is a stock ford system
First thing to do is enter the default code that is listed in your owners manual. This will turn off the anti theft system. If you have turned it off and are still experiencing this problem then you will need to pull the error codes and see what is keeping your theft system activated. It will either be a PATS module or the Powertrain Control Module (PCM) A scan tool should be able to pull the trouble codes from both modules. Usually the dealer scan tool is more updated and able to read all modules. Click on the link below to view the 2000 Ford Excursion owners manual:
http://www.scribd.com/doc/29182853/2000-Ford-Excursion-Owners-Manual
http://www.supermotors.net/clubs/fordexcursions/forums/thid-2436-excursion-keeps-dying.--please-help
Posted on Oct 13, 2010
When I open the drivers side door without a key in the ignition the bell dings. I have a 2000 ford excursion limited.
try wiggling the ignition switch and see if it stops if it does it is the key in the ignition warning switch persoally i wouldn't worry about it if it is if it does you will have to replace it and ign tumble most likley
Mar 20, 2011 | 2000 Ford Excursion
2000 ford excursion v10 driving down the road
Honestly you should send it into the dealer. I don't think guessing will help you. Typically it is a dirty connection into the steering column (behind the ignition key) But diagnostics need to be run and a look at the VSS system (through a good scan tool) is needed to confirm.
Apr 17, 2010 | 2000 Ford Excursion
My excursion cuts off when put in reverse
IS A GAS OR DIESEL? IT COULD BE A LOTS OF THINGS, POSSIBLY NEUTRAL SAFETY SWITCH, IT COULD BE AN IAC (IDLE CONTROL MODULE) MOTOR, & LOTS OF OTHER THINGS DEPENDING ON IF IT IS A GAS BURNER OR A DIESEL ENGINE.
Dec 05, 2009 | 2000 Ford Excursion
2000 Ford Excursion Diesel has check engine light of P1391
glow plugs preheat the fuel to help the engine start.....when its hot outside its not that bad...the colder it gets the harder it will be to start with bad glowplugs..
Nov 17, 2009 | 2000 Ford Excursion
2000 Ford Excursion diesel when shut off interior and running board lights stay lit for long period of time or won't go out at all which in turn causes the cars battery to go dead.
You have a door ajar switch sticking in one of the doors. Start with the drivers door,open door and spray a liberal amount of WD40 into the latch on the side of the door. Then open and close the doors firmly several times. This usually unsticks them.
May 12, 2009 | 2000 Ford Excursion
2000 ford excursion wont start
The venture runs without problems, but then off-key upside down but nothing works, even though the battery is full. you only hear something like relay switch and then dead
Feb 12, 2009 | 2000 Ford Excursion
2005 Ford Excursion disel
check for a recall on the crank position sensor, it will make it stall also the fuel transfet pump might be getting weak, it is on the frame rail just under the drivers door it keeps pressure up in the line and when they get hot might not keep pressure up.dont listen to anyine sayong to spray AMYTHING down the throat .there are electronics in the air line into the air cleaner and at minimum kill a sensor but starting fluid and the like are extremely flamable and the 6.0l engine has a intake heater and will ignite the fluid and cause a explosion. yes it does happen, Im a diesel mechinic for 20 years.I have a 2000 diesel w/ 7.3. did you get a check engine lite on when it started or shut down?
Jul 27, 2008 | 2005 Ford Excursion
Vehicle Parts & Accessories Logo
258 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
