Question about Zebra 203DPI Printer
I'm getting a "ribbon in" error when printing Direct thermal, and there is no ribbon installed. Any ideas? The error occurred when the end users changed the label roll. Labels are loaded correctly, and are the proper type. I've changed the setting to Thermal Transfer and back to Direct Thermal, but it seems to fix it only for a bit. Every time we've done something, we've rebooted.
  • tanya_pozzob Jun 27, 2011
    Unfortunately, our label printers are not installed locally on our computers (i.e. not available under the computer's device list). We print via direct IP. There is only the interface available to change it to Direct Thermal -- "use printer settings" is not available at all under the Media Setup. Thanks for the response!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 51 Answers
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences"
Choose the "Advanced Setup" tab
Change media type to "Direct Thermal"
Be sure that "use printer settings" is NOT selected at the top left
Click OK and you should be good.
Note that any labels created prior to this change will need to be changed inside each label under the label setup.
Posted on Jun 21, 2011
Warning ribbon in V53.16.7Z
The "ribon in" warning is because you set the printer to print DIRECT THERMAL insted THERMAL TRANSFER. The first mode is for printing directly on the thermal labels, not for using a ribon. The ribon sensor detects that a ribon is pressent and you get this message. You need to change the printing mode to Thermal Transfer from the printer Setup Menu, or from the Print Driver instaled on PC.
Jan 19, 2015 | Zebra Office Equipment & Supplies
I have a few Datamax-I-4206 printers and some of them have the Thermal Transfer ribbons and some do not....Do I need to have Thermal Transfers or cant I just print to them without it?
If the unit is set up for either(with the thermal trasnfer option- ribbon unwind and rewind assembly) you can use either ribbon- with thermal transfer stock, or direct thermal- with direct stock.
You can tell the stock by rubbing something across the stock to see if it will turn black, that is direct thermal stock.
If using direct, go into the setup and select media type- direct thermal.
If using ribbon- use thermal trasnfer option. But remember to install ribbon before calibration as ithe printer will error on out-of -ribbon.
Dec 31, 2010 | Datamax DMX I-4206 Printer
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
Zebra Z4 Error message
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
Feb 04, 2010 | Zebra Z6M Plus Thermal Label Printer
My zm400 keeps reverting back to direct thermal
did it stay on direct thermal if you not doing any print job ?
then i assume you the problem is when you printing .In ZEBRA DESIGNER, there's a printing preference that can be set up... i think u selected direct thermal when you print with zebra designer, that's why whenever u start printing, it show RIBBON IN again.
the solution is, Just changed the printing method from zebra designer.
if you aren't using zebra designer, then the problem at your driver. Open Printer & Faxes, then right click your Printer and klik on Printing Preferenced. There u can set up the printing method to Thermal Transfer.
The thing is....... changing the Setting from LCD panel won't change the setting on the driver.
i hope this will help you
Aug 19, 2009 | Zebra 203DPI Printer
110xi111plus error code: warning ribbon in? what does that mean?
that ribbon occures when you are set for thermal direct printing in the driver or printer and you should be set for thermal transfer in the driver in printing defaults off of the advanced tab and the printer needs to be set for thermal transfer in print method in the setup menu. thermal transfer is printing with black ink ribbon and paper and thermal direct is just chemicaly treated paper.
Jul 02, 2009 | Zebra Printer 140-751-00000
Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Oct 27, 2008 | Office Equipment & Supplies
Z600 wont print, ribbon error
in the switched at the front of the printer you can configure it to direct thermal mode.. or if you are using printer driver please configure it also to direct thermal mode..
Jul 08, 2008 | Zebra Stripe S600 Thermal Label Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
How to say to the priter we don´t use ribbon
If you are printing in direct thermal mode (without a ribbon):
· Check your software settings and make sure that the print type is 'direct thermal'. If your software package requires the use of a Windows driver, also make sure that the driver is set for direct thermal printing.
If you are printing in thermal transfer mode (with a ribbon):
· Check your software settings and make sure that the print type is 'thermal transfer'. If your software package requires the use of a Windows driver, also make sure that the driver is set for thermal
transfer printing.
Check to see if there is any dirt on the ribbon spindle gears or on the ribbon motors. For the latter
you will need to remove the electronics cover. If there is dirt in either of these areas, try vacuuming around the motors and/or the spindles to remove as much of the dirt as possible.
Mar 17, 2008 | Toshiba TEC B-472 Thermal Label Printer
Zebra 203DPI Printer Logo
199 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
