Question about RCA 35V432T 35" TV
Sound only works in VID mode with audio/video hookups either through a DVD player or video game consoles. Sound does not work with just cable hookup with coax cable.
    Top Expert:
  • RCA Master
  • 74,468 Answers
Just adust the system reception to auto mode in your tv and retry. You can do it through remote control menu, going to sound options. Check tha sound system to auto. If the Tv has only PAL and SECAM system; NTSC signals do not output sound. If the tv is multi system compactable, making system reception mode to auto may help you.
Posted on Oct 14, 2010
Cannot get new DVD player to work on Denon AVR-2307CI Receiver
TRY TO FIND DVD PLAYER RESOLUTION SAME TO THE RECEIVER....MAY BE IT WORKING..
Dec 28, 2013 | Denon AVR-2307Ci Receiver
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Screen on Philips Flatscreen HD has turned green there is sound on all Freeview stations only, no picture but DVD player works perfectly well and in full colour Why is this and what needs fixing. Freeview...
If the hookup is HD from a box you have Green(video) Blue and red--check first they are connected properly at both ends. Component would also use two more cables for audio.
If HDMI maybe a bad cable or issue there. HDMI has issues with and creating no sound problems.
If a DVD player does work fine it means a hookup issue of some kind or a very odd problem in the set(unlikely).
SD TECH
If using HDMI at least attempt a component hookup.
Apr 22, 2012 | Televison & Video
My super nintendo has no sound and I replaced the sound module and still no sound please help !!
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Check your system connections to ensure they are firm and correct.
Remove and reload the Game Pak, pressing firmly to ensure it is locked in place.
Many Game Paks have an option that controls one or more volume variables. These may have been set to maximum volume during the manufacturing or testing process. Consult the game manual for directions on how to adjust the settings. You can usually get to them by going into the Options screen.
Remove the AV cables and reinsert them with a slight twisting motion. Make sure the Video Cable (the yellow plug) is in the video input. Plugging it into an audio input will cause buzzing. Also, make sure none of your audio (red) cables, are plugged into a phono jack on your stereo, which can also cause buzzing. Finally, make sure the Stereo AV Cable is plugged into input ports, not output ports. For a detailed review of the hookup, please check our hookup instructions.
Some TVs or VCRs may have special Audio Inputs that don't allow the volume to be controlled by the TV. They are intended to be controlled by a different device, such as a home theater amplifier. Check your manual for the TV or VCR to see if this is the case for your unit.
Some TV and VCRs have a small switch, usually found near the AV inputs, that is used to allow components to send sound out to the TV speakers. Check your manual for the TV or VCR to see if this is the case for your unit.
If you are using the Stereo AV cable for your hookup, remove the plugs and reinsert them with a slight twisting motion. Make sure that you are plugging the yellow cable into the video input, and that the audio cables (red and/or white) are plugged into the audio input jacks on your TV or VCR.
If you only have one audio input, and one plug is hanging, that will result in a loss of sound. Either purchase a Y-adapter or access the game's option menu, and when available, set the game sound option to Mono.
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
Click here if the troubleshooting doesn't help
RF Hookups
Try switching both the TV and RF Modulator to a different channel (3 or 4). Try adjusting the Fine Tuning control on your TV to see if it clears up the sound. A particularly strong TV station (or cable TV) signal may be broadcasting on Channel 3 or 4 in the area, causing interference. For a detailed review of the hookup, please check our hookup instructions.
Try disconnecting the antenna/cable wire from the RF Switch. (You will have to reconnect it again for regular TV viewing.) If this option works, an AB Box may be needed. These can be purchased at various home electronic stores.
Dec 03, 2010 | Nintendo Super NES Console
Digital audio doesn't seem to be detected. I've got directTv hp, and two dvd players hooked up. The input mode is Auto. When DP or analog, no sound comes out. when Auto, I get background noises, but no...
Optical cable from DVR or DVD to receiver. TV to monitor out. Digital audio is only through optical hookup. Then hook your mic up and run the YPAO and set to auto to run the sound basic set up then when done, go back a fiddle with the manual set up and turn up speaker volume, set sound modes, etc
Jul 27, 2010 | Yamaha HTR-5790 Receiver
Sound from tuner but no other devices
The RX-V365 cannot process audio from the HDMI cables (you will still be able to hear it on your TV), you will need to run a seperate coaxial or optical cable into the audio input for the relevant component on the back of the RX-V365.
Dec 26, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
When i use a hdmi cable in my samsung dvd hd860 there is no sound, why is this
I had a Samaung DVD VR-375 and it plugged straight in and had video and sound both with one HDMI cable. BUT I also have 2 new LCD TV's that provide and additional audio hookup to go with the HDMI hookup. Look for an audio OUTPUT ( L and R) from your Samsung HD860 and electrically connect it to your TV input associated with HDMI marked L and R.
Sep 17, 2009 | Samsung DVD-HD860 DVD Player
Element 32'' LCD TV, has picture but no sound
The S-video cable doesn't have hookups for audio, only video. It's better than the video coaxial cable. But, you still need to hook up the right and left audio coaxial cables.
Feb 09, 2009 | Element ELC-HS321 32 in. LCD TV
WII audio and TV audio simultaneously
do you have surround sound, if you do you will need to plug the wii hookups into the surround sound, or plug it into the tv and shut the surround sound off.
May 31, 2008 | Nintendo Wii Console
RCA 35V432T 35" TV Logo
48 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
