Question about Shoprider Dasher 3 Wheel Mobility Scooter
On a full charge the power runs down fast,I replaced the batteriesbut it still does it?
  • 692 Answers
Chas then the problem has to be either your charger or that you have a bad battery. Even tho its new doesn't mean its good. If you can take the batteries to a local battery shop or mechanis and have him load test the batteries. If you find one tyhat fails return it to the place you bought it and have them replace it under warranty. If the batteries pass the load test then your charger is suspect. Hope this helps you
Posted on Oct 14, 2010
I have a problem with fuel shortage or Lowe voltage. coast to lite excel oration.
driving , or parked, engine on or off. (sure key on)
please post full clear symptoms.
post all the car does good and bad.
parked, idling and driving.
my guess is, you were driving, then looked at the cluster
  1. and the fuel level dropped fast. (power loss 12vdc that is)
  2. and the voltage gauge, dropped,(well it didnt lie , it did drop)
  3. this means the battery charge is too low, and falling.
  4. the battery is bad. or
  5. the charge system( I never said to replace a part) is bad.
  6. or the battery lugs are rusty. clean them.
battery is 12.6vdc rested, engine off
battery volts running is 13.3 to 15vdc, , if not charge system is upset or battery so bad the charge system shuts down.
Mar 28, 2015 | 2011 Jeep Liberty
Samsung galaxys 2 drain battery fast
The power cell should only get warm if you have it powered on all of the time. That is natural. 6 hours is short, and that may be one of two problems, the time of charge is too short, or the battery is dying. HINT! If you replace with a NEW battery; you must set the battery memory for the start. That means, when you first charge it, make certain it gets a long 24 hour charge to full. Use the phone until the device shuts down because the battery was exhausted. Now Do a full long term Charge. That process will set a Memory for the Power Cell and allow you to fully charge and discharge the battery from there on. One more thing...if you use a Charger Device, make certain it is working OK or else the Battery will not charge well.
Dec 12, 2013 | Samsung Galaxy Tab 2 7.0
Craftsman fast charger
run all 3 batteries down to full dead then fully recharge. some times this can help
Nov 27, 2013 | Garden
Why does it idle fine and then when you give it gas it boggs down
A two-stroke engine idles because a very small hole behind the throttle plate lets a tiny amount of gas through to keep the engine running. At full throttle the air moving through the carburator pulls gas through the venturi vaporizing it. With the motor at idle, if you give the motor full throttle very fast the first charge or two that get into the cylinder are almost completely fresh air with vary little or no gas mixed in. It takes a revolution or two for the motor to pull air through the carburator fast enough to get a fully charged mixture of gas and air into the cylinder so you get full power. This effect is especially pronounced when the motor is cold, the gas doesn't vaporize as well when the motor parts are cold. If you give it throttle slowly or let it warm up the effect should go away.
Feb 22, 2012 | Poulan Pro PPBP300 30cc 2Stroke Gas...
Some of my phones will not stay charged even though I have let it on the unit. Do I need to replace the batteries?
If they charge, but then run down fast, it's a sign that the batteries are just too weak to take/hold a full charge and, yes, it's time for replacements.
Nov 01, 2009 | Uniden Cordless Phone
My battery dosent last 1 hr from full charge new comp. 2 days old
you posted this in the desktop section I am assuming that this might be for a laptop? If it is then you might have gotten a bad battery. This does not normally happen, but it is possible.
Another thing that could be affecting it is the power settings. If you have the power settings set to maximum, then they will drain your laptop battery super fast, and about an hour sounds normal.
Another factor that might run a battery down fast is heat. If a laptop is used without proper airflow underneath it, it will drain the battery fast also. To solve this, you can use your laptop on a flat smooth surface, like a desk or table, or invest in a USB laptop cooler pad.
Dec 01, 2008 | HP Computers & Internet
Battery runs down fast.
hello there....well its quite simple...
how old is your phone ?
i am assuming its an old phone so it is time to change the battery...you will see that batter is slightly puffed or out of shape ...in that case you should immediately change it
if its a new phone....then check if blue tooth is on or off....it should be off....and if you use the phone a lot then also the batter will run out in 3 hrs and 30 minutes of talk time...playing music as well as keeping the camera on for a long time will drain the batter
so it depends on how you use it ....if you have more question we will take it from there
Hope this help
Cheers
Aug 05, 2008 | Nokia N70 Cellular Phone
Nokia n81 running a new battery down in 6-8 hours on standby mode
Even if the battery is new, if it is not charged properly it can run down pretty fast. To reset the battery I recommend running the battery all the way down - charging the battery all the way back up to full - and then repeat. Also, make sure you do not charge the battery after it is full. Most phones or charge units have signals to tell you when the battery is fully charged. Do not charge the battery overnight.
These are the best ways to protect the life of a battery.
Jul 30, 2008 | Cell Phones
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Shoprider Dasher 3 Wheel Mobility Scooter Logo
78 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
