Question about True TD-65-24 Commercial Refrigerator
My True beer cool stopped cooling last night what should I do ?
    Sergeant:
    Novelist:
  • 193 Answers
That is a broad question. Lets do a checklist. When you plug the unit in the compressor behind the grill on the front should come on and the fan in front of the compressor should come on. The radiator in the compressor compartment needs to be clean from all dust and grease. Many times this is overlooked and can cause real problems by letting the compressor overheat. Now look inside and find the fan cover. It hangs from the inside top of the cooler. It should also be running. If either fan is not running the unit will not cool. Sometimes there is an obstruction, such as someone pushing a six pack up against the fan cover and pushing it into the fan. The fan down by the compressor is sometimes blocked by the cardboard shroud that is built around the fan. Also in a few cases rodents have gotten caught in that fan. If everything is running, you will have to look deeper into the compressor compartment. There is a screw in the front of the radiator that hold the compressor unit in the cooler. Unplug the unit from the wall. Remove that screw and slowly and carefully pull the compressor unit towards the front of the beer box. It will slide almost all the way out. You will see a coil of copper tubing at the back of the compressor that allows enough slack in the lines to slide this unit out. When you push this unit back in it helps to have someone behind the cooler to pull back on that coil as you push the unit back into the machine so it does not get crimped. With the compressor unit pulled out, plug it back in at the wall. If your compressor is running and you have proper amount of refrigerant, the small copper tube from the compressor to the radiator will get very hot, enough to burn your finger, after two or three minutes. After 10 minutes the larger copper line that is usually enclosed in a rubber sheathing should get cold. One way to know if you have a burned out compressor is to listen to the compressor and fans when you first plug into the power outlet. A bad compressor will usually try to start for 2 or 3 seconds and then click out. While it is trying to start the fan will slow down because the compressor is pulling way too many amps and is pulling power away from the fan until it clicks out again. If you can hear the compressor come on and run but it makes no heat to the radiator, you probably have a refrigerant leak. Your freon is gone or almost gone. If it was a slow leak you would usually notice that the cooler does not seem to cool like it once did. If it was working good and suddenly stopped cooling, the most likely problem is a bad compressor. Changing a compressor is usually beyond the average do it yourselfer because it requires welding the unit in place and gauges and a supply of refrigerant which is almost impossible to get without a liscense. Let me know what you find out.
Posted on Oct 13, 2010
    Director Badge:
    Uploaded 100 video answers.
  • True Master
  • 488 Answers
How to replace compressor. True air beer chiller.
Posted on Mar 01, 2015
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
Jan 14, 2012 | True Refrigerators
My true back bar cooler dosent cool it is not iceing over
If you can gain access to the compressor, you will see 2 copper lines going to the compressor. One is smaller than the other. VERY CAREFULLY lightly touch the smaller line while the unit is running. If the compressor is running, that line will be extremely hot.
Start there.
Let me know if I can be of further help.
May 27, 2010 | True TD-65-24 Commercial Refrigerator
Will not cool down could it be the cap tube
Im working on a TRUE beer cooler m/n AEA4440YXA & it will not cool down below 50 degrees. I have replaced the cap tube & weighed in charge of 134A (11ozs.) this is what the tag says...still not cooling. Does anyone have any sugestions ? Condenser & evaperator fans are running fine & compressor is pumping well.Puzzled
Oct 22, 2009 | True TD-65-24 Commercial Refrigerator
My Kenmore 596.50692001 side by side stopped working last night. The fan was not working at first. It eventually came back on and the unit seems not to be cooling. The compressor was a little hot???. The...
replace your fan,cause is no cooling the compressor,and check if the compressor didnt burn out to.if my info was of any help to you please leave me a comment ,thankyou.
Sep 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Viking Refrigerator stopped cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 12, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
BEER COOLER ICE PROBLEM
First, dont overstock your beer, good circulation is key. Make sure your condenser coils are clean. Find a happy setting with the help of a thermometer to cool between 35 - 42 degrees. To defrost I put big zipl-loc bags of ice on top of beer. Turn temperature all the way up (the compressor will cut off but the fan will keep running) for a few hours. When the ice is thick i put HOT water in a squirt bottle and spray sections in the ice. Play around with that and see if it works. Hopefully you don't have a bad condenser. Good luck!
Jan 31, 2008 | True TD-95-38-LT Beverage Cooler
True TD-65-24 Commercial Refrigerator Logo
370 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
