Question about Dryers
HOW DO I CHANGE THE CORD FROM A 4 COLOR CORD TO THREE STRAND GRAY CORD DO YOU HAVE A DIAGRAM OF IT OR INSTRUCTIONS?
  • 5,911 Answers
The following link explains the differences between a 3 and 4 prong applaince cord and how to properly install them:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
NOTE: If you are installing a 3-wire gray cord that is not color-coded, the oouter two wires (left and right) are the HOT leads. The center conductor is NEUTRAL or GROUND.
If you have any quesitons about this repair, please post back and let me know. I hope this helps you.
Posted on Oct 13, 2010
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
I need to switch the power cord from a four prong to a three prong. The three prong that I purchased is a 30 amp. Will it be sufficient? Only one of the strands on the three prong is labeled. The...
30 amp. will work just fine...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Feb 06, 2011 | Dryers
Need to change cord from 4 wire to 3 wire
All you have to do is make sure the middle wire on the strand of three goes to the middle screw the other two just go to either side. Your ground screw just gets tightened down without a wire. I do this everyday.
Aug 21, 2010 | Whirlpool GEW9250 Electric Dryer
Need wire diagram for 4 wire cord [color code[
Here is a tip that will help you with that problem...
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
May 17, 2010 | Dryers
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Jul 23, 2009 | Dryers
Tdk mp100 headphone jack
Each of the rubber covered cords running to each ear piece has two fine strand wire bundles inside. The right ear piece has a red colored strand and a copper colored strand. The left ear piece has a green colored strand and a copper colored strand. The wires are coated with an insulation lacquer. The lacquer burns off when you heat the wire for soldering.
Repair item: 3.5 mm stereo headphone jack, shrink tubing
Plan for strain relief:. These headphone wires can't take any tension at all. You need to crimp the black cords to the headphone jack somehow.
Slide strain relief and headphone jack housing over the over the rubber covered headphone cord.
  • You need to plan a way to relieve the pulling stress on the solder joints where the two headphone cords enter your replacement headphone jack.
  • Try shrink tubing if you have it.
  • If you have some thermal shrink tubing, slide a piece over the headphone cord end before stripping the wires.
  • Slide the headphone jack casing over the headphone cord also.
Strip each headphone cord 5/8" using the 18 gage setting of your wire stripper..
Hold each headphone cord in a "third hand" soldering assist tool and tease the green, red and copper bundles apart..I wore a 10x Magnavisor and I used a sewing needle and a bright light.
Twist the copper colored strands from both headphone cords together. They are the common ground wires. The copper colored bundle will attach to the headphone jack ground.
Apply a dab of solder to the end of each of the three bundles of wire. You will see and smell the insulating lacquer as it burns off. Keep most of the wire bundle cool.
Position the two strand headphone cord and the 3.5 mm headphone jack in the third hand soldering stand.
  • Plan where you can crimp the headphone cord. Crimp it when ready.
  • The green == left channel wire goes to the tip of the 3.5mm jack.
  • The red==right channel wire goes to the middle of the 3.5 mm jack
  • The copper colored wires go to the ground of the jack..
  • Measure resistance, 31 ohms per earpiece.
  • Screw the jack cover on and finish the strain relief craftsmanship.
Nov 28, 2008 | TDK MP100 Professional Headphones
II HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL.
Your issue is as follows;
"iI HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL."
A 3 prong cord should be wired as follows:
1. 1 end of cord connects to 1 outside terminal.
2. The other end of the cord connects to the remaiing outside terminal.
3. The center wire connects to the center terminal.
4. A separate ground wire should be attached from the dryer chassis, then to a metal cold water line, or an exterior grounding rod.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 17, 2008 | Whirlpool Dryers
Cord Connection
If your dryer cord is flat and gray, then simply attach the two outside wires from the cord to the left and right screws on the terminal block. Connect the center wire of the cord to the center screw of the terminal block. The only important wire is the center wire of the cord goes to the center screw of the terminal. The two outside wires don't matter.
Jun 13, 2008 | Roper RES7646KQ Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
