Question about Whirlpool Duet GHW9150P Front Load Washer
I have an error code of F11 what does this mean
  • 3,230 Answers
Well the F/11 code is generated when there is a communications error between the two main control boards in the washer. These two boards are the Motor Control Unit (MCU) and the Central Control Unit (CCU). A common problem is the wiring harness jiggling loose; remove and reseat it and that usually fixes it. You need a multimeter to check out for the problem, there is a a tip you may try to resolve this issue. follow the link below -
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Good Luck!!
Thanks for using FixYa!!
Posted on Oct 13, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    F11 ault code. what does that mean?
    Hello Polly, this is Z. I am happy to assist you!
    If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
    Mar 19, 2014 | Frigidaire Kitchen Ranges
    Kenmore gas range F11 error code
    The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
    Dec 13, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    F11 error code
    The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
    Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
    The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
    Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
    We are getting code F11. What does that mean?
    Hello. the F11 trouble code means Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    These are circuit boards within the machine and one of them will have to be replaced. Most folks leave this job up to the service technicians.
    Feb 02, 2010 | Kenmore 46462 Front Load Washer
    F11
    these error codes are not specific FDL can mean door latch failure .it can also mean the ccu board has failed also F11 can mean mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor. if you do not know how to diagnose with out error code you may end up buying wrong part. sometimes doorlatch is not problem central control board CCU is
    Feb 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Hotpoint wt741 f11 what does this mean
    Hotpoint Error Codes.
    Hotpoint washing machines are among the most common found in the Uk and like any mechanical device they will occasionally breakdown or develop a fault and need repairs.
    Being a very popular make means that most parts supplier will keep there parts in stock and because so many suppliers keep Hotpoint parts stock this also drives competition hence driving down the price of parts if you should ever need them
    One problem many people including some engineers face when faced with a faulty Hotpoint washer is knowing what the error code mean, so here are a list of error codes and there meanings for Hotpoint washing machines
    These error codes can some times have a E in front of the number and not a F as shown here, but the meaning of the code is still the same
    # F11 - This means there is No hot fill.The ambient temperature is probably below freezing perhaps due to the plumbing becoming frozen. Also verify that the taps are on or if the drain hoses are kinked.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Dec 26, 2008 | Washing Machines
    Could you tell me what F11 code means?
    F11 error code means there is a problem with the Control panel. Could be melted wiring, etc, since you left the oven standing. However, you can try unplugging the device from the power socket for about 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
    Oct 13, 2008 | Frigidaire Kitchen Ranges
    Whirlpool Duet GHW9150P Front Load Washer Logo
    46 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
