Question about Mitsubishi WD-73827 73" HDTV DLP TV
I need a serial number for the wd 738 dlp series 65 inches by mitsubishi
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
SOURCE: mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Posted on Sep 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: i have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blin
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Posted on Sep 26, 2008
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
CaptainHawk1
  • 345 Answers
SOURCE: My mitsubishi 65-inch dlp tv
It's either mirror hinge fatigue or dust on the inside.
Mirror hinge fatigue can be fixed by putting a solid color picture (white or gray works best from what I understand) on the display and letting it sit for 20 minutes.
If it's dust, someone is going to have to go in there and clean it out.
Also could be a defective micromirror device.
Try the first suggestion and if it doesn't work, you're going to need a technician to take a look at it.
Posted on Nov 23, 2010
Mitsubishi 65 dlp
SOUND LIKE A BAD COLOR WHEEL...HEAR A LINK TO SEE IF THAT THE SOUND YOU ARE HEARING ....http://www.youtube.com/watch?v=hUiYRqrNxxU
Dec 24, 2013 | Televison & Video
Mitsubishi dlp
which of the three lights is flashing red?Let me know and I will assist you with the issue.
Mar 21, 2013 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Mitsubishi wd-65638 65 in hd tv dlp tv usb i dont no how to work it
I think you need to download the manual for you to easy follow how it works...
try this link:
http://safemanuals.com/user-guide-instructions-owner-manual/MITSUBISHI/WD-65638-_E
try to click the right box and click the boy to the left side...rate and comment then download..
Dec 11, 2011 | Mitsubishi WD-65638 65" DLP HDTV
Video on 65 inch Mitsubishi Tv model WD-65638 is not working how may i reset this or even fix the situation.
If you have the original working Mitsubishi remote you can try a soft restart:
Menu, 1,2,3, enter
SD TECH
Aug 31, 2011 | Mitsubishi WD-65638 65" DLP HDTV
Our 65 inch mitsubishi tv will turn off on its own and the light flashes red. What does this mean?
You have a defective Main PC board. Part number is 934C328001. Out of warranty cost should be around $340
Mar 21, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Screen shows white dots over entire screen 65 inch dlp
Try cleaning the optical lens for dust if still the same DMD chip is defective and needs a replacement.
Dec 29, 2009 | Mitsubishi WD-65731 65" HDTV
Mitsubishi WD-73827 73" HDTV DLP TV Logo
164 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
