Question about KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range
Oven won't heat after attempt at self clean (self clean did not run)
We tried to run the self clean this AM and it would not run, display said/says 'door'. Now the oven won't heat.
I saw that that one of the self-clean latches was hitting the door frame. I got it to latch but the display still says 'door'. I then just tried to skip the clean and to bake but it won't. I read some posts that said the thermal fuse was a likely problem but since I know the self clean didn't run, I'm not sure...
Other:
The light stays on in the oven. I'm not sure if this is a new problem, but might be related. I saw some whirlpool posts where they said 'hold the door light plunger down for a while and the self clean will resest' but I can't find anything analogous in the oven's door frame.
Appreciate your suggestions
  • 7 more comments
  • DavidIac Jun 02, 2008
    OK, I'm handy and can work an ohmmeter. Do you have a diagram by chance on how to get to the thermal fuse and what it looks like? How do I check the temp control? fyi both baking and broiling are off...
    Kitchenaid KDRP467KSS09 Dual Fuel (Electric and Gas)
  • DavidIac Jun 03, 2008
    There is a door latch assembly. I cannot find the other (door lights switch)
  • DavidIac Jun 06, 2008
    The first person helping me has gone silent
    Is a burned fuse obvious or it just so likely that I should do it anyway?
    I'll take the back off this weekend and see. The self clean didn't run at all, so it didn't get hot as part of the self-clean event, but maybe it burned out before.
    I thought your last post was 'do you see these parts I've circled?' and my answer is yes I see the latch but not, there is no door-light switch. I don't see a response after that?
  • DavidIac Jun 08, 2008
    Will do. Part is one order; I'll let you now asap as the part is installed
  • DavidIac Jun 09, 2008
    I don't understand what you would have me do next. I have a door latch but there is not light switch
  • DavidIac Jun 11, 2008
    The old fuse showed continuity/no resistance, same as the new fuse, but I replaced it anyway. Unfortunately, the oven didn't heat up. If I turn to self-clean as a test, it still say "door". Next thing to check? Another posting said 'replace the control panel thermal fuse' but I can't seem to find that part...
  • 3,037 Answers
If you are looking for the thermal fuse still, you will need to remove the back panel to get to it. Please tell me what the current situation is, what you've tried and what the problem or question is right now. thanks
Posted on Jun 06, 2008
  • 6 more comments
  • Benjamin Patri
    Benjamin Patri Jun 06, 2008
    Well instead of waiting for a response, these ovens tend to blow the thermal fuse when the self cleaning feature is used (major design flaw). Replacing it should solve your problem, I would call Kitchenaid and complain about this and see if they will send you a free one otherwise it will cost under $50.
  • Benjamin Patri
    here is the part you will need to order
    http://www.partselect.com/xq/aspx/Invent...
    from partselect.com
    PartSelect #:
    PS374264
    Price:
    $38.74
    there is a diagram with this part there too
    http://www.partselect.com/ModelFrames.as...
    let me know if you need anything else
  • Benjamin Patri
    Kitchenaid dual ovens like this have a habit of blowing this fuse, so that is the most likely problem and will prevent the oven from working if burned out
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • Benjamin Patri
    Benjamin Patri Jun 09, 2008
    sounds good, thanks for the update
  • Benjamin Patri
    light switch? Are you talking to me?
  • Benjamin Patri
    Benjamin Patri Jun 11, 2008
    alright, then it seems that the latch that was hitting the door is broken and needs to be replaced as the fuse was fine. If the old fuse showed continuity, then you should have said so as it would be good for sure then.
  • Benjamin Patri
    Benjamin Patri Jun 28, 2008
    Brigadier General:
  • 3,614 Answers
Kindly check the heating element area esp.. the thermal fuse, and also the temp control for any problem..
Thank you
Posted on Jun 02, 2008
  • 2 more comments
  • micromaster
    micromaster Jun 02, 2008
    i want to know first the exacr unit that you have there..?
  • micromaster
    kindly wait...
  • micromaster
    micromaster Jun 03, 2008
    kindly check for this part..
    Let me know here again..
    Regards,
    micro
  • micromaster
    micromaster Jun 06, 2008
    if you noticed i have responded on your last post..just take a look when was the date i post my last solution before this one...
Lg oven not heating after self cleaning. code f9
F9 stands for oven no heating. It will be displayed if oven temperature readout when oven temperature doesn't exceed 150F/66C in less than 5 minutes from set time. I would say you may have a heating element malfunction..
Oct 23, 2016 | LG Kitchen Ranges
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
After doing a self clean on a whirlpool oven model rbs245pd06 it will no longer heat on bake or broil.
Unfortunately you have found out the hard way about the self cleaning feature... they cause many problems...
Here is a tip that I wrote about that and it includes some things you can try to get you oven to unlock...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Mar 30, 2010 | Ovens
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
Self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Tappan self-clean oven door locked shut, fan keeps running
Did you give it time to cool down? If so, probably a control issue.
Sep 01, 2017 | Tappan TGF320 Gas Kitchen Range
Oven door won t open after self clean cycle
Frigidaire CGEB27S7CB built in wall oven. Set to clean oven yesterday and after cycle door stays in locked position. Can not open door. I tried re setting clean cycle and cancelling but will not unlock door.
Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range Logo
232 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
