Question about HP Pavilion dv7-1245dx Notebook
HP Pavilion dv7-1245dx will only run on battery power.battery will not charge?
  • Doctor PC
    Doctor PC Oct 13, 2010
    If run on batt. why dont charge?
  • HP Master
  • 32,281 Answers
The power adapter could be faulty or the power socket in the notebook could be faulty.
Please click on this link to determine the fault and fix :-
Normal 0 http://www.fixya.com/support/r4799950-laptop_battery_power_supply_problems
Posted on Oct 13, 2010
2 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: how to put hp pavilion dv7-1245dx key back on the
They just snap back on but notice if the key is broken then what you need to do at this point is by a replacment key or buy a replcement keyboard.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jul 31, 2009
Hp pavilion dv6000 battery not chargering
First try to reset the battery to see if it helps any by doing the following: Turn off all power saver settings on your laptop, disconnect the laptop for the ac adapter. Then use your laptop and run the battery down ignoring any low battery messages until it dies. Then let it fully charge for a night without turning it on, and see if it has saved any charge. If it still hasn't saved any charge, it seems like the only option is that its a dead battery and needs to be replaced. Best of luck!
Jul 14, 2010 | HP Pavilion dv6000z Notebook
My hp pavilion dv 6000 does not stay charged even when plugged in
Batteries fail alot, and what they dont tell you is that modern Li-on batteries get damaged if you leave your computer plugged in all the time.
You need to charge the battery and then run it on battery power.
Sounds like your battery is knackered, you can get replacements. I googled your model and found 1 for £23
http://www.1pcdiy.com/hp-compaq-laptop-batteries/1481/
Jul 12, 2010 | HP Pavilion dv6000z Notebook
Pavilion dv6700 AC Power. My DV6700 performs perfectly on battery, but will not charge the battery or run straight off AC. AC Adaptor, Batteries and AC jack have been tested in fine working order. Any...
Hi, believe it or not?; sometimes the current in certain areas of the home or apartment have separate power circuits from the main direct current system. Check to make sure there is electrical current running through your socket, and or light switch to open the circuit. Thanks, paul7of9
Dec 29, 2009 | HP Pavilion dv6000z Notebook
Battery would only last 5 min. after unplugging but now says plugged in but not charging...Time for a new one? 2007 hp pavilion
Run a battery check. For this go to desktop, hit F1. In the help screen choose Power and Battery. Go to Battery check.Connect your power supply and run the test. It will give you the status of the battery.
Nov 27, 2009 | HP Pavilion dv6000z Notebook
Hp dv1000 won't power up running on power cord or battery
PLease check both of them. First check the power cord by replacing the power cord and see if its charging or the battery and see if it is charging.
Thanks
Aug 13, 2009 | HP Pavilion dv1000 Notebook
HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
Aug 13, 2009 | HP Pavilion zd8000 Notebook
My laptop is not turnnig-on!
Try removing the battery and running from the AC power supply only. If this works, your battery probably can no longer hold a charge and the battery will need to be replaced.
Removing the battery allows the power supply to power your laptop rather than trying to charge a dead battery
May 17, 2009 | HP Pavilion dv2214us Notebook
HP DV6000 Battery problem
Bring it back to the repair shop if it has still repair warranty. They should take care of it.
Dec 04, 2008 | HP Pavilion dv6000z Notebook
Problem with my hp notebook battery!!!
discharge your battery compleately and then
charce your battery for 16 hrs add then discharge compleately
and charge till 100% batt level approx 2hrs
that will help
Nov 03, 2008 | HP Pavilion dv5020us Notebook
HP Pavilion dv7-1245dx Notebook Logo
349 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
