Question about Acer Aspire One Netbook 8.9" Notebook
Please help! When I turn on the Acer Aspire one netbook, it jumps straight to the "InsydeH20 setup Utility" screen, I tried every exit options but it keeps jumping back the same screen, just can't go into Windows. Last time I turned it off normally, don't know what happened....
    Sergeant:
  • 172 Answers
Check your bios setup if your drive with a windows is in the first boot setup.
Posted on Oct 13, 2010
Insydeh20 setup utility
Some are fixed, they would be in gray. What options are you trying to change?
May 01, 2013 | Acer Aspire Computers & Internet
Bios nonva 5600 aspire
The BIOS Setup Utility is a hardware configuration program built into your computer's BIOS (Basic Input/Output System).
Your computer is already properly configured and optimized, and you do not need to run this utility.
However,if you encounter configuration problems, you may need to run Setup.
To activate the BIOS Utility, press
m
during POST (when "Press <F2> to enter Setup" message is promptedon the bottom of screen).
The setup screen displays BIOS as follows:Navigating the BIOS UtilityDuring setup,all Fn function keys and power saving functions are disabled.
There are five menu options:
Main, Advanced, Security, Boot and Exit.Follow these instructions:
To choose a menu, use the cursor left/right keys (zx).
To choose a parameter, use the cursor up/down keys (wy).
To change the value of a parameter, press p or q
Press
while you are in any of the menu options to go to the Exit menu.
In any menu, you can load default settings by pressing t
You can also press u
to save any changes made and exit the BIOS Setup Utility.
hope this helps
Aug 02, 2012 | Acer Aspire 5600 Series 5630-6951 Laptop
Wont start up it goes to a option menu to reboot but it dont then it gives me the settings but wont do anything else just a black screen with a disk read error occurred press ctrl+alt+del to restart i do...
From what you have described it sounds like you have a bad hard drive. If you have a CD/DVD drive try getting a Windows Installation CD/DVD and booting from it.
May 02, 2011 | Sylvania G Netbook Meso Netbook
Factory reset without using a disk and ALT + F10 doesnt work
his MIGHT work:
1. Click "Start," "Turn Off Computer" and then "Restart", if it is on. If your computer is off, turn it on by pressing the power button above the keyboard.
2. Press the "F2" function key on your computer's keyboard to enter the BIOS utility.
3. Use the laptop's right arrow key to scroll to "Main." Confirm that the "D2D Recovery" is "Enabled." If the D2D option is "Disabled," scroll down to the option using the down arrow key. Press "Enter" to change the option to "Enabled."
4. Use the laptop's right arrow key to scroll to "Exit." The "Exit Saving Changes" option will be highlighted. Press "Enter" to save the settings and exit the BIOS utility. Your Acer Aspire will restart.
Reformatting the Acer Aspire
1. Press the "ALT" and "F10" keys together while your computer is restarting and the Acer logo is showing to enter the Acer Aspire's reformatting utility.
2. Follow the on-screen prompts. Your laptop's hard drive will reformat and the original applications will be reinstalled. Your computer will restart after the reformatting process is complete.
3. Enter your name and other personal information when prompted during the Windows operating system setup process.
Mar 22, 2011 | Acer Aspire One PC Notebook
ACER first it said this ntel UNDI, PXE-2.1 (build 082) Copyright (c) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.13(2008/10/15) Check cable connection..! PXE-MOF:...
Press F2 on boot. go to bios, ie insydeh20 setup utility. goto boot menu. select legasy in type. select your usb drive and hdd as a first boot device. save and reboot.
Jul 02, 2017 | Acer Aspire One PC Notebook
Following instructions for factory settings on asus notebook but when i hit f9 on start up nothing happens please help
ASUS netbooks have a Boot Booster which renders all activity obsolete, you need to disable the boot booster first.
First you need to access the BIOS/Setup Utility, on an ASUS machine/Motherboard you need to hit "Del" or "F2" not F9 at this stage.
Once in the Setup Utility, using your arrow keys navigate to the Boot options page. Using down arrow key navigate to Boot Booster option and hit Enter to disable. Once the option is disabled navigate to the last tab Exit, and using down arrow key to navigate to Exit and Save Changes.
Your laptop will then reboot and as soon as it does you may start to hit "F9" which will start the Factory Settings utility. You can then follow the on screen instructions to continue wit the resetting of your machine.
Jan 13, 2011 | ASUS Eee PC 1000HE Netbook
My Acer D250 netbook starts show a white screen the reboots it self, sometimes it not only shows white screen but also gray or it run colourful lines then it restart. When it restart it start working fine...
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Dec 28, 2010 | Acer Aspire One PC Notebook
Acer aspire netbook won't boot. How can it be restored?
This recovery process helps you restore the C: drive with the original software
content that is installed when you purchase your notebook. Follow the steps
below to rebuild your C: drive. (Your C: drive will be reformatted and all data
will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 Check to see if Acer disk-to-disk recovery is enabled or not.
2 Make sure the D2D Recovery setting in Main is Enabled.
3 Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press <F2> during POST.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Jul 02, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One - blue screen only when try to boot
You may have to remove and reset the HDD and Memory on the unit.
Next, you will recv. the F-2 to continue or F-12 to enter setup.
Enter setup and change date and time.
Save and try.
You may have a damaged HD or boot partition and reloading the operating system will be necessary.
Reseating the HD will assure that you have a good connection and the same with the memory.
Also, if the unit has been dropped, you may have a damaged HD and may need to change it.
Sep 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Start up issues
While booting, just before you see the Windows Logo, Press F8 and choose "Boot from Last Known Good Configuration"
Regards!
Jul 11, 2009 | Acer Aspire One PC Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
1,384 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
