Question about Whirlpool ED5THAXMS Side by Side Refrigerator
Freezer side gets very cold, but the refrigerator side is slightly cool. Replaced thermostate but the results are the same.
  • 254 Answers
It may be a defrost issue. If the freezer is not defrosting then ice encases the fan motor behind the back wall of freezer and wont allow it to circulate the cold are to refer section. To see if that is the issue check behind the freezer back panel if it is iced up try unthawing it, have towels on the floor it will make a mess, if it starts cooling again after you thaw it out then you know its a defrost issue and it will work until the ice builds up again. You may need a new defrost tstat, heater or timer.
Posted on Oct 13, 2010
The thermostate switch on and off but the fridge is not cold. The Freezer works 100 percent
You are 60% solved... The thermostat controls the freezer. Cold air from the freezer is blown into the refrigerator to cool it. The fridge dual control electrically controls the freezer, but uses a simple air damper to control the freezer air into the fridge.
Look for:
Stuck damper, stopped air circulation fan, possible ice/frost blockage. The problem is in the airflow path between the freezer and the fridge side.
Jan 08, 2011 | Refrigerators
Refrigerator side not cooling freezer sides is working i had the fan motor replaced but still fridge side not cooling.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dygjdgh
Jul 14, 2010 | Samsung RS2534 Side by Side Refrigerator
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not getting cold enough. Do I have a coolant leak?
First check the refrigerent level and gas leak could result in poor cooling.
Block in the drier or capillary section could result in poor cooling
Thermostate could be defective
Defrost the freezer chamber in case you have excess ice formed in the freezer chamber.
Jul 06, 2009 | Refrigerators
Freezer is cold but not freezing the ref is not cold
Simple! Refrigerent leak only results in poor cooling. Check your thermostate also to make double sure of the cause.
Jul 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer won't freeze
compressor may be the problem,by pass the thermostate connections & chelk cooling replace if working.some sort of leakage may also be the problem.
Mar 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool ED5THAXMS Side by Side Refrigerator Logo
69 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
