Question about Pentair 3hp Whisperflo Pool Pump In - Ground
My pentair plus pump will not turn completely on. It makes a loud noise but never kicks on.
    President:
  • Pentair Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Oct 13, 2010
My pool pump is suddenly making loud noise at times
It sounds like you either have a bad bearing or a broken impeller. This will not get better wioth time. You need to get it repaired.
Sep 02, 2015 | Pentair WHISPERFLO PUMP .75 HP FR EE...
When I turn on filter the pump makes a loud noise, then kicks on but runs loud.
these are known to have rear end bell issues , the motor will need service by your local pool pump motor repair guy. cost about 75.00 .. if you keep running it it will destroy the motor and a new motor will be your only choice .Leave feedback for your favorite fixya guy.. that would be me the pool pump motor repair guy in longwood Florida.. don't forget to prime your pump after a repair !!
Mar 26, 2012 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
The pump is making a noise, but it is not turning. It will kick off after about 5 seconds
THE PUMP PICTURED IS A PENTAIR THE LITTLE CAP ON THE TOP OF THE MOTOR IS THE RUN CAPACITOR, TAKE IT OFF AND HAVE IT TESTED. BE CAREFUL THESE CAN HOLD VOLTAGE AND GIVE A NASTY SHOCK !SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING..JAY
May 31, 2011 | Pentair Whisperflo 15 HP Pool Pump WFE6...
My Whisperflo was making a buzzing noise while pumping. I turned it off to clean the strainers and now when I turn it on it makes a loud buzzing noise and the motor does not spin. The impeller moves...
it's a bad start/run capacitor. It's under the hump on top of the motor. DO NOT touch the terminals with your bare hands in case the capacitor is charged. You can replace it with an exact match.
Sep 06, 2010 | Pentair 1.0 Hp Whisperflo Pump
Pool heater won't kick on
check the gas line pressure; (if this was a homeowner installation you will not be able to check the gas pressure) dirty filters are the number one cause of heater malfunction. before you do anything else break the filter apart and clean completely and recharge with diatomaceous if applicable. also check the pump baskets and make sure there is no debris in the basket or blocking the impeller inside the pump. if this doesn't solve your problem call pentair tehcnical support
Jun 22, 2009 | Pentair MINIMAX NT TSI IGNITER
Pump motor makes loud noise when pump comes on
If this is a high pitched sound, then this sounds like you have bearings that are starting to go out.  There is not much that you can do to prevent eventual failure.
The only other option that I see is that there is something causing friction inside the pump between the impeller and diffuser.
Dec 28, 2008 | Pentair 1.0 Hp Whisperflo Pump
Pentair 3hp Whisperflo Pool Pump In - Ground Logo
80 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
