Question about Whirlpool LER4634J Electric Dryer
Dryer will not turn when on. Please advise what the problem could be?
  • 5,911 Answers
The most common cause of a dryer that will not turn on, is a blown thermal fuse, bad power cord, or a broken drum belt.
If the voltage at the wall receptacle is correct, check the voltage again at the terminal block where it connects to the dryer. Make sure you UNPLUG the dryer and remove the the small access cover where the power cord is installed. You should read 220-240VAC at the wall receptacle and terminal block. If BOTH readings are good, the problem is INTERNAL to the dryer. If bad at the receptacle, you need to double check the power source that feeds the wall recepatacle. Some homes use two separate 120VAC breakers instead of one 220-240VAC breaker. Make sure the breaker(s) is not tripped. If the reading is normal at the wall receptacle, but bad at the terminal block, replace your power cord.
If the problem is internal, the thermal fuse will be mounted on the blower fan housing. It is a small plastic looking component (usually white in color) with two wires attached to it. Disconnect the wires before taking any resistance checks. If the fuse is good, it should read something close to zero ohms. If bad, you will read an infinite reading. These fuses DO NOT reset and must be replaced if bad.
If the dryer belt is broken on this model dryer, the dryer will still heat, but will not run. You would still be able to hear the motor running if this was the case, and the dryer would still produce heat. If your dryer does not exhibit these symptoms, then your belt should still be good/
Another cause of a dryer that will not turn on, is a broken door switch. An easy method to test the switch is to open the door and press by hand. If the dryer drum light is working, you should be able to toggle the light on and off. If the switch is found to be defective, it must be replaced.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have competitive pricing, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations that you can use to locate and properly identify any parts you may need. If the model number is correct, the part number you may need are as follows:
If you have any questions about these repairs, or need instructions on how to access any of these components, please post and let me know. I hope this helps you.
Posted on Oct 13, 2010
My stackable dryer will no longer spin...it makes a noise like it's trying but it will not budge...please advise. Thank you in advance for any assistance you can provide.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 01, 2011 | Frigidaire Dryers
We have a 10 year old Whirlpool Dryer Model #LGB6200KQ0 drum is turning but no heat. Could you please advise?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Whirlpool LGV4634JQ Gas Dryer
My whirlpool dryer is making a loud humming/rattling sound and it is making a burning smell immediately after it is turned on. I have checked the filter and also the exhaust to make sure it was hooked up...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Sounds like a bad motor...
heatman101
Aug 16, 2010 | Whirlpool Dryers
The dryer drum will not turn.
Could be belt gone if the drum is quite easy to turn by hand. Or motor in @worst
Apr 01, 2010 | GE Profile Harmony DPGT750EC Electric...
Roper dryer
check thermal fuse
Jul 18, 2008 | Roper Dryers
Bosch wtl 5400 elect. condensation dryer
I have a WTL 5400 electric condensation dryer (bosch). All of a sudden one day, it would not turn on. The lights are on, the filters are clean. Please Advise.
Harriet Scannon
Feb 18, 2008 | Bosch Axxis WTL 5400 Dryer
Kelvinator ED 56 Dryer
reach inside and see if the drum turns real easy. It should turn real easy even wth wet clothes in it. if it hard to turn then the motor aint gonna get going gonna run hot and quit.
Jun 27, 2017 | Dryers
Whirlpool LER4634J Electric Dryer Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
