Question about Monitor Audio Radius R360 Subwoofer
My sub doesn't seem to be working I hook it up but no sound comes out???
Evrything hookup there is no sound iget a good signal in the back of the sub so whats the problem
try connecting a speaker to the sub output terminals at low volume and see if it has loaded output, if it works , your subwoofers voice coil is open/blown
Jan 29, 2014 | Behringer EUROLIVE B1500D-PRO Active 15"...
Popping noise
Check the sub with a multimeter. It should read the ohms it is rated at when you hook it to the positive & negative inputs. It its off your coil if bad.
Mar 16, 2013 | Alpine SWR-1241D Car Subwoofer
2009 Jeep Sahara sub woofer not working
if the wires are connected then you ether have a blown amp or sub. try hooking up a diff speaker to the wires if it works your sub is blown. if it doesnt your amp is blown
Mar 13, 2013 | Audio Players & Recorders
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
Subwoofer turns on and is hooked up, but no sound.
The signal don't seems to be present to the sub input.
Try change the wire betwen the audio system and the subwoofer.
Spider Guy
Mar 15, 2010 | Onkyo 630-Watt 7.1 Channel Home Theater...
My sub flickers on and off in my truck!!!
could be a number of things loose wires bad ground fuse on its way out or internal problems
Feb 13, 2009 | Profile BAJA HA700M Car Audio Amplifier
Infinity ps-10 powers up but no boom
Try hooking up a different signal input to your powered sub, another stereo or even a dvd players audio output to the sub will work for a test. Just make sure the subs gain is down before starting. If it still not producing sound, the subwoofers amplifier is bad. I hope this helps.
Oct 10, 2008 | Infinity PS-10 Subwoofer
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Onkyo 805 sub hook up problem
Talked to tech support at Onkyo and there seems to be two (2) places you can hook your sub up to. I placed mine in the wrong slot. So please double check where you placed the sub connection.
Jan 05, 2008 | Audio Players & Recorders
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Monitor Audio Radius R360 Subwoofer Logo
37 people viewed this question
Top Monitor Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Monitor Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
