2002 Kia Optima Logo
Posted on Oct 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installation kia 2002 optima fan belt - 2002 Kia Optima
Anonymous
Level 2:
  • Expert 454 Answers
  • Posted on Jan 05, 2011
Anonymous
Expert
Level 2:
Answers
454
Questions
0
Helped
178857
Points
793
Hello css_trish and thank you for asking your question here on fixya.com.
I have actually written a general information article that will walk you through the general process of changing the fan belt on your
2002 Kia Optima. It will also point you to the resources you need for getting the diagrams of how the belt needs to go back on.
Here is a link to that article:
How to change the fan belt on your
2002 Kia Optima
If this has helped you in any way, then feel free to follow my Twitter account for more great money saving tips and tricks. twitter.com/acoates23234
I follow back, too. :)
Thanks for reading.
Where to buy a timing belt, water pump kit fo my 2004 Kia OPTIMA
For 2001-2006 Kia Optima Engine Timing Belt Kit ...
eBay https://www.ebay.ca > ... > Timing Kits
For 2001-2006 Kia Optima Engine Timing Belt Kit with Water Pump 2002 2003 2004 ; Approx. C $415.18 ; Delivery. Free 4 day shipping. Get it between Wed, Nov 22 and ...
2004 Kia Optima Engine Timing Belt Kit With Water Pump
Advance Auto Parts https://shop.advanceautoparts.com > find > 2004-kia-opti...
We currently carry 2 Engine Timing Belt Kit With Water Pump products to choose from for your 2004 Kia Optima, and our inventory prices range from as little as ...
2004 Kia Optima Timing Belt Kits
CarParts.com https://www.carparts.com > ... > 2004 > Timing Belt Kit
Get the best deals on an aftermarket 2004 Kia Optima Timing Belt Kit. Lifetime Replacement Guarantee. Free 60-Day Returns. Order today!
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 62px;"> Rating: 4.3 · ‎27 votes
Advance Auto Parts https://shop.advanceautoparts.com > find > kia-optima...
Low prices on Engine Timing Belt Kit With Water Pump for your Kia Optima at Advance Auto Parts. Find aftermarket and OEM parts online or at a local store ...
1helpful
Serpentine belt diagram on a 2002 kia optima
Google "DAYCO belt routing guide"
I'm trying to locate the fuel safety shut off switch on a 2002 Kia Optima
THERE IS NO FUEL SAFETY SWITCH ON A 02 OPTIMA . IF YOUR HAVING TROUBLE GETTING IT TO START YHEY HAVE ISSUES WITH TIMING BELTS TAKING OUT THE CRANK SENSOR WHICH WILL KILL SPARK AND INJECTOR PULSE .
Can a novice replace a 2002 Kia Optima Alternator? What resources can i find to guide me?
Follow your nose and you will be able to it ,just remember to disconnect the battery first and draw a fan belt diagram before you take it off
2answers
2002 kia optima,,, whining noise that stops when turning left
power steering pump probably went out.. if you can easily get at the belt and are any kind of mechanically inclined, remove the drive belt to the p/s pump and then start the car if the noise is gone then its probably part of the power steering pump
2helpful
Need diagram of timing belt installation
the diagrams for 2001 to 2005 models are same:--- here is the link to diagram:---- http://www.2carpros.com/car_repair_information/year/2002/make/kia/model/optima/2002_kia_optima_timing_belt_diagram_marks.htm
----------This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya....
Change belts on 2002 kia optima
Not sure what engine you have , but I had an 02 rio with the 1.5 L . The serpentine belt did not have a tensioner (spring loaded) pulley , the belt tightness was adjusted by pivoting the alternator mount.
If you are takling about the Timing belt , the tensioner pulley wont move (even though it is on a spring ) untill you loosen the bolt in the center.
How to Install Belt KIA Optima 2003
how do you install a belt on a kia optima 03
Tension bolt
It has to be located just above the belt near the power steering pump. Common sense will let you know that the tension bolt will tighten or lossen the belt.
Top Kia Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Kia Expert? Answer questions, earn points and help others
