Question about Coby MP815 Digital Media Player
It wont charge period. i've tried different chargers.
    Scholar:
  • 38 Answers
Sounds like you have a defective unit. If it is possible to access the rechargeable battery make sure it is installed correctly. If the product is still under warranty and you find no issue with the battery (corrosion, overuse or just general decay over time) contact the Coby support line for further troubleshooting tips or to set up service. (remember any attempt to fix the product yourself might void the warranty, please read the warranty information before you do anything)
Coby support line: (800) 727-3592
Posted on Oct 13, 2010
Tablet doesn't turn on, it shows a battery with an triangle and this symbol!
When you have the charger plugged into the tablet and wall outlet does the triangle change to a lighting bolt if it doesn't change try a different changer either the charger or charging port or charging cable might be bad
Dec 31, 2014 | Tablets & eReaders
The usb for charging but it is not charging.
are you using the charger that came with the phone? I ask because I've run into in the past that if you try and use a different charger it may not work on your phone. you should use the one that came with the phone. having said that, you might want to try a different usb charger if that doesn't work it's probably the battery. Li-Ion batteries have charging circuits built in that can fail and also prevent the battery from charging if it's gone bad.
Nov 09, 2012 | Sony Ericsson Xperia Arc
My nokia E5 won't charge, I've tried another charger but still nothing
can you see the pin in the charger socket? these can get bent, other wise looks like your charge socket has come free, from the board
May 16, 2012 | Nokia E5 Cell Phone
My apple ipod touch 64G wont charge
If you've tried without success to charge your iPod touch with a wall charger and by connecting it to computer with a ipod cable, and you've ruled out that the cable is functioning properly, contact Apple Support or go to an Apple Store for assistance. Launch your Web browser and navigate to support.apple.com to see various options for online and phone support, as well as to locate the nearest Apple Store.
May 01, 2012 | Apple Audio Players & Recorders
Hi, i've had my Samsung genio touch for over a year now and i've had no problem untill now, the phone will not charge up, i've tried putting the charger in a different socket and taking the...
a possible battery or charger problem.
check if you can charge using a diff. charger,if you can?then the charger is the problem,replace it.
but if you can charge w/a diff. battery?replace the battery. :)
Sep 09, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I am using sony ericsson z550i it is not getting charge can u plzzz give me a solution
Dear,
first of all try cleaning the pins of your charger and mobile charging socket with petrol or kerosine oil.
then see if it works,
if still the problem persist, then their may be the fault in your charger or mobile charging socket. Or electric socket where you put your charger for charging!
try charging your mobile by putting your charger in different switch board, if still it wont work, then try charging your mobile with different charger, if your mobile is getting charge, then get sure that problem is in your charger,
its time to buy a new charger.
original charges cost=900
duplicate charges cost=100
regards!
Aug 17, 2011 | Sony Ericsson Z550i Cellular Phone
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Blades wont stop till battery goes flat,then rotate again when you try charge it up
First, chopper must be "off" when charging.
If helicopter is powered off and blades move when it's hooked to the charger, then you have an incorrect charger. It's tricky as they all look the same. At one point I had 3 different "syma s107" helis that all used different chargers. Around 7 different Chinese and Taiwanese factories/companies produce the "syma" branded birds, and often with differing but very similar parts. There are at least 3 circuit board designs, different wiring patterns, and a couple batteries.... I've heard of people receiving a charger in the box with their 107 that didn't charge it. NEVER run battery dead. You will ruin it. What charging method are you using? Does it fly normally when charged? Do the blades ever move when it is powered off and not hooked to charger?
Let me know,
thanks PvT
Jan 07, 2011 | SYMA Toys industrial New Syma S107 Mini...
Lg viewty wont charge
Ok, there`s 3 things that could be wrong.
1.battery
2.charger
3 phone fault.
Your best bet is to go to where you bought thephone.
Tell them whats happened, ask to try a new battery,if that doesn`t work (using your charger), try with a different charger,if those two don`t work then it will be a phone fault.
If you have a warranty use it for an exchange in my opinion. Hope i`ve been of help.
Dec 14, 2009 | LG KU990 Viewty
Coby MP815  Digital Media Player Logo
60 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
