Question about HP LaserJet 3330 All-In-One Printer
Hope its not a lemon....
Light keeps flashing scanner bulb warming but no progress
    Novelist:
  • 85 Answers
Hi Try pulling both cables and leave both disconnected for at least 1 minute... It will reset to factory settings... it will solve the problem or confirm that you need to get it serviced.
Good Luck!
Tinteiros (Ebay)
Posted on Jun 02, 2008
Won't go to menu
Had a similar problem on a HP MFC3330
Fixed it with the following video aid:
"how to fix the scanner bulb warming up error hp 3330 or repair 3380 scanner bulb warm up problem - YouTube"
http://youtu.be/lqG_nmi3vC4
Hope it helps...
Jul 27, 2014 | Dell 1600n All-In-One Laser Printer
My scanner screen says that the scanner bulb is warming up,but nothing happens. Also my cancel light continually flashes. What could be the cause of this?
Scanner Bulb Error Message
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpl12028&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=66366
ISSUE:
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner's inability to find the home reference point.
SOLUTION:
Perform the following steps to walk the scan assembly from the home base and resolve the issue.
1.
Remove and replace the power cord from the unit.
2.
Wait approximately 35 seconds for the scanning assembly to "walk out" and then quickly remove the plug again.
3.
Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4.
Replace the plug and let the product fully finish the boot cycle.
If this does not resolve the issue or the issue returns, upgrading the product firmware may help. The firmware upgrade can be found at the HP Web site Downloads, Drivers, and Notifications page .
Hope I help you a bit.
You can also send me questions on my
personal email - christian4122@yahoo
Your's Truly,
Christian from HP
Mar 27, 2011 | HP LaserJet 3330 All-In-One Printer
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Scanner bulb warnning
The 'scanner warming up' error is caused by dirty scanner optics. What happens is the scanner initializes the lamp and starts reading the scanner pickup waiting for the light to get to a certain brightness level. When the optics get dirty from dust or smoke then the light getting to the scanner pickup is reduced so the unit thinks the scanner bulb has not reached the correct brightness so it says wait. What you will need to do is dis-assemble the top portion and clean the scanner optics. We have a step by step guide to do this procedure posted on our web site at: http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/ This should get you back going again.
I hope this helps you out, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 16, 2010 | HP LaserJet 3330 All-In-One Printer
My Printer says it is warming up and it wont
i have found that in alot of cases that these units stall on scanner bulb warming because the scanner cannot find home. do you hear a noise like the carriage motor contnues to just move a little bit? what happens is this the ccd knows its home by the brightness of the refected light off of the white carriage home strip on the back side of the glass cover its reflected to a photo cell which is tripped telling the ccd its home. if the bulbs the white strip or the mirrors inside the ccd get a light dusting of dirt on them they dimm this light and the photo cell will not be triped thus creatiing this problem. with a flash light you can see if these mirrrors are fogged. clean them with a q-tip and alcohol. about 65% this fixes it.
Dec 02, 2009 | HP Officejet 6310 All-In-One InkJet...
Fax and cancel lights are flashing
I found this solution at HP website. It worked for me. Good luck!
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner’s inability to find the home reference point.
SOLUTION:
1. Remove and replace the power cord from the unit.
2. Wait approximately 35 seconds for the scanning assembly to “walk out" and then quickly remove the plug again.
3. Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4. Replace the plug and let the product fully finish the boot cycle.
Oct 08, 2008 | HP LaserJet 3330 All-In-One Printer
Epson 3490 scanner red light flashing message that printer cannot properly communicate with pc
If the start button light is flashing red, it is because of one of the following problems:
  • The scanner is not connected to your computer properly or your software is not fully installed.
  • The transportation lock is locked. Slide the lock to the unlock position.
Jul 16, 2008 | Epson Office Equipment & Supplies
Scanner error 6
Scanner errors are as follows for that model:
Scanner error #
1 = dark find
2 = LMW temp find
3 = bulb warm up from off
4 = bulb warm up from coarse
5 = cal label find
6 = doc original find
7 = LMW final find
8 = cal label find after scan
9 = cal label find prior to standby
10 = doc original find prior to standby
11 = bulb warm up from standby
I would see if there is an original on the flatbed glass (platen), or if something is obstructing the scanner view.
If the error persists, replace the scanner
assembly or the formatter pcb
Apr 22, 2008 | HP LaserJet 2840 All-In-One Printer
Scanner not working - get error message
First, check to see if the bulb lights up, if not you have bad bulb. the bulb can be ordered separately. if the bulb is good, you have a problem with the main board.
Nov 02, 2007 | Epson Perfection 1240U Flatbed Scanner
HP LaserJet 3330 All-In-One Printer Logo
85 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
