Question about Frigidaire PLHS267ZA Side by Side Refrigerator
Ice despencer arm broken. bought new one. how to install??
Today I posted the same question... how to replace the ice dispenser lever/arm but decided to keep looking for a solution then stumbled upon this manual (http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man) On page 14 you will see that part #23 (the bottom that catches dripping water or ice) slides forward and back. Slide this back and you will see 3 screws at the bottom. Remove those screws then gently push/slide the entire black frame upwards to release it. Hold the faceframe and disconnect the wire that runs to it (you might need long nose pliers for this). At this point, you should be looking at something like whats in the picture I posted. At this point, I decided to unplug the fridge and shut the water flow just as a precaution. Now, there are 3 other screws visible to you (NOT the tiny screws holding the green circuit board)... unscrew those 3. This will allow you to sligthly pull the piece forward and as you do that, you will see a wire connection on the left side. It is a snap-on connection that you can easily remove and reconnect later on... disconnect them. Pull the panel forward so you can look and work on the back side of it. It will be a bit hard to pull forward and I recommend that you not pull too far so as not to break the water hose that runs to the water dispenser. Since you already have the replacement part, try to figure out which one that part is and see how it is held in place. You will notice 2 tiny steel plates, one on each side of the part you are going to replace, held by screws. Remove those plates to release the part. Removing the part and putting in the new one was based on feel so you will have to try to get this done with some jiggling and pushing and pulling :). After you have the replacement part in place, just put everything back the way you found them. And dont forget to reconnect the 2 wire connections you disconnected earlier. Goodluck!
Posted on Nov 15, 2010
  • markjdv Nov 15, 2010
    oops, it seems the picture did not get posted and there is no way for me to edit the posting. Let me know if you need to see the picture and I will figure out a way to send you the picture.
  • Parson Shawn Feb 20, 2011
    Thanks a bundle. Your instructions were perfect. Huge help. Got 'er done in 15 minutes!
Kenmore Ice maker arm is stuck up. Tried pushing it down and now mybe broken.
The cheapest place to buy a new one is on e-bay. put in your model #. I paid less than $ 75 dollars for mind. good luck
Nov 15, 2013 | Kenmore Refrigerators
HOT POINT SIDE BY SIDE ICE MAKER IS PRODUCING ICE BUT IT WILL NOT DESPENCE ICE OR WARTER
If you press the botton for ice or water do you hear anything? If not the switches could be out or your fountain assembly may be bad. Check to see if you hear noise. You can even wiggle the arm to see if it activates.
If you need further assistance or have questions please feel free to comment me back.
Jul 27, 2011 | Hotpoint Refrigerators
Ice maker sticks and it stops giving ice.
Does it stick when it is trying to despence the ice from the tray? The bracket the slides the ice out of the tray may be broken. If the bracket is just getting stuck it means that your ice is sticking inside the tray due to the teflon coating being worn out. Replace ice maker
If you need assistance on how to install the icemaker or a place to order one please feel free to contact.
Jul 27, 2011 | Kenmore Refrigerators
We have a Whirlpool dish washer gu1500xt not sure how old it is. Problem nat cleaning was well sometime we find soap despencer open with the soap cake on it. Also finding left over dirt near the top right...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Feb 05, 2011 | Whirlpool 24 in. GU1500XT - Multiple Color...
Ice maker control arm has broken and ice machine keeps making ice. How do I stop the icemaker? And, then, how do I fix or replace the control arm (which appears to have snapped at the point that the arm...
Good day,
You will have to remove the ice maker. Usually 2 screws or clips on top and one screw on the bottom, as well as the plug that supplies the electrical power.
Since you'll need a new arm anyway, I would suggest you take the ice maker to any decent sized appliance parts house, and see if they'll pull the the old stub out and install a new control arm.
If that doesn't work, you'll need to replace the whole ice maker.
If you want to see if you can remove the stub yourself, unsnap the front cover. You'll see a semi-solid state type board. It is held in with 3 screws. Remove those, pull the board off, and inspect the area we are talking about. You might be able to get it out, but if not, go back to my first suggestion.
Oct 11, 2010 | Amana ARB9059CS Bottom Freezer...
Ice Storage box
I have a Whirlpool Gold fridge model # GS5SHAXN LOO. The problem is this...often I'll hear a noise from fridge and when I investigate, it is always that a piece of ice has gotten stuck in the tray part of freezer and not falling into dispenser. Also, because of this it seems (not positive) that it won't begin the process of making any more ice. Annoying that we can't always have ice when we need it. Any solution to this would be great.
Thanks in advance!
Apr 17, 2010 | Whirlpool GS5SHAXN Side by Side...
Ice maker does not stop making ice
id say this could be the bucket thermostat which cuts out when enough ice has been made this will need to be replaced
Apr 13, 2009 | Refrigerators
Frigidaire PLHS267ZA Side by Side Refrigerator Logo
277 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
