Question about Toshiba Tecra 9000/9100 Keyboard
The mouse pointer on my Toshiba Tecra 9000 will randomly drift away and off the screen. It happens more and more often. I can successfully use an external mouse, but don't like to use this machine remotely with an external mouse. Do I need to replace the driver or something?
  • Toshiba Master
  • 6,993 Answers
The problem is either a software of hardware problem.
When I say software, i mean, the driver of the mouse pointer/pad need to be re-installed, and when I say hardware problem, I mean, the mouse pad of your system might be defective.
Also restoring the system might help to solve the problem. To perform system restore, go to Start menu > All programs > Accessories > System tools > System restore. Allow the computer perform the restore and your computer will be restarted. Once the system boots up, try again.
If that doesn't solve the problem, then know for sure that its an hardware problem, the mouse pad might be defective. You will be needing the help of a repair man if that be the case.
Good luck.
Posted on Oct 13, 2010
Drifting mouse pointer
Go to Control Panel - Mouse - Pointer Options - and uncheck 'Enhance pointer precision'.
Feb 28, 2010 | Dell Precision M60 Notebook
Mouse pointer drfts to the right side of the screen. I have a touch pad and a mouse button on the keyboard. Even when I connected my usb mouse that pointer drifts as well. I'm not able to control the mouse...
see if your touchpad settings have a setting that controls the sensitivity on the area around the touchpad where you rest your hands on the laptop. I forget what it's called, but most laptops have a setting to control that, so when you rest your hands on the laptop it doesn't affect mouse movement. When you rest your hands, if the sesitivity is too high, the mouse pointer will move when you place your hands to rest on that area.
Jan 10, 2010 | Toshiba Satellite Pro M15-S405 Notebook
Tecra 9000 problems on keyboard
reinstal windows xp and during instal select keep old programs do not format it then you have acces to al installed programs befor
also save you emails and adressbook (wab) file they wil be overwritten
if problems stay try to connect extern keyboard on usb port with a cable you can buy on computer store
Oct 06, 2009 | Toshiba Tecra 9000 Notebook
Re toshiba techra 8000
Some laptops have a touch pad between the keyboard and the edge of the laptop. This works like a mouse except you slide your finger around the pad to move the mouse pointer and the buttons next to the touch pad are the left and right buttons.
Other laptops have a small round button in the middle of the keyboard which is a mini joystick and it is used to move the mouse pointer around, it will have a couple of mouse buttons at the botom edge of the keyboard.
You can connect a normal mouse to your laptop, it is mush easier than using the laptop's touch pad or mini joystick.
Sep 16, 2009 | Toshiba PA3121U - Satellite Pro 6000,...
Hello, I just received a used Toshiba tecra 9000 laptop and it is missing the "mouse" and I need a part number so I may buy one.
Since the Tecra 9000's mouse is actually the Accupoint that's located within the keyboard, it cannot possible be missing the mouse (unless it's missing the keyboard).
Unless you're missing the Accupoint cap. Only place to order them is from Toshiba Support.
Feb 03, 2009 | Samsung UpStage SPH-m620 Cellular Phone
Toshiba tecra 9000 laptop missing mouse "toggle"
Great! The part number you seek is P000329030, Below is a link to purchase a refurb keyboard. They work just as well as a new one but at less cost. I think a new board will run you between $85-$100 dollars depending on where you go. (My company, C2Solutions, sells it for $84.95 new and free shipping.) When you do get it, it's fairly easy to install the new one. Good Luck and glad to help. Franklin
www.priorityelectronics.com
th_p000329030.jpg P000329030 Toshiba Tecra 9000, 9100 Series Laptop Keyboard
Item #: P000329030
Type #: Laptop Keyboards
Item Condition: Refurbished, 90 Day Warranty more-info.gif Price: $59.99
Feb 03, 2009 | Toshiba Tecra 9000 Notebook
Disable onboard mouse
TouchPad Enable/Disable ( Fn+F9 )
Dec 24, 2008 | Toshiba Tecra A3 Notebook
Toshiba Tecra: How to turn of directional buttons
I'll bet it's the mouse in the keyboard that is at fault rather than your left arrow. Try pressing the little joystick mouse device in between the G and H key and above the B key to the right when your pointer drifts to the left. If it's the joystick moving it and then letting it rest should re calibrate it.
Let us know whether or not the joystick is the culprit or not so we may continue to help you?
Sep 06, 2008 | Computers & Internet
Drifting cursor
optical mouse (laser) will note work on shining surface (glass)...
PLEASE RATE ME ( FIXYA )............................
May 26, 2008 | Toshiba Tecra M2 Notebook
LAZY MOUSE POINTER
This is often a symptom of a malware infection; update your AV program, then run a full scan of your entire HDD. If you can't find the problem with your AV program, you have a second option. Open Internet Explorer, then open the housecall.trendmicro.com website and do an online scan of your system. You can also download Hijack This directly from there, in case you need it to remove something manually... Good luck; let us know what you find. This could be a REAL nasty problem, but with some time and patience, you should be able to resolve this without resorting to drastic measures.
Mar 31, 2007 | Toshiba Refurbished TECRA 9000. PIII-M...
Toshiba Tecra 9000/9100 Keyboard Logo
93 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
