Question about Microsoft Windows XP Professional
My computer monitor goes blank after microsoft windows loads just before the logon screen pops up i can hear the desktop and startup music but cant see it help?
  • 340 Answers
Try this.. reboot your computer and when you see the first logo come up hit f8, this will take you into a black screen and give you a few different options. You will see one that says restore computer to last known good configuration. Select this and hit enter. It will give a list of dates on the next screen, choose the one when you know your computer was working correctly, hit enter and let it complete the process. This will not remove or alter any of your files, it is just "setting your computer back to a previous date. Hope this works for you, which it should. let me know if you have any further issues.
If you find this helpful, pls leave feedback, thx :)
Lori
lori@computersolutionsbylori.net
www.computersolutionsbylori.net
Posted on Oct 13, 2010
I am in charge of a computer account here at work and have about 15 ACER 1916B monitors that are all inop...The monitors power up and show the ACER startup then show the windows startup to only go...
This problem is caused by 2 things, the computer is set to a higher resolution that the monitors can handle, so when the graphics card drivers kick in as windows boots the screen goes blank, this is normally the problem for people trying to hook there computers to normal lcd televisions not monitors, as monitors generally are able to show higher resalutions.
In your case because you are using computer monitors, the problem will be caused by the refresh rate settings on the windows, most desktop lcd monitors have a fixed refresh rate of 60hz, my guess is your computers are set as 75hz therefore as windows boots the screen goes blank because it dosent support that high a refresh rate.
To resolve this problem, just before windows boots press F8 on the keyboard, this should bring up a black command prompt screen, at the top you will see the safemood option, tab up to it and press enter, this goes to windows but dosent load any drivers including the graphics driver. Once loaded right click the mouse in the middle of the screen, and bring the display properties window up, in this window click on the settings tab, click on advanced on the bottem right of the window, this will bring up another window, click on the monitor tab, on this window you will see the screen refresh rste setting, click the small arrow and set this to 60hz and click ok, in the other window reduce the resalution down abit using the slider, click apply and close the window, then reboot the mechine as normal, the problem should now be sorted, any problems post me back. thanks and hope this helped.
Sep 22, 2010 | Acer AL1916W 19" LCD Monitor
The monitor comes on then goes out.
Problem with appearing normal windows desktop... go to Safe Mode to remove any possible pop-ups or vga driver to see where the windows stands normally.
Oct 04, 2009 | HP Compaq FP5315 15" LCD Monitor
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
My PC startup is fine then I get to logon screen. Each user account is different. I have WinXP SP3. I sometimes takes a little longer to hear logon sound, then pauses and finally the desktop comes up....
sounds like your computer is bogging down from to much bloatware. do a disk clean up. and uninstall any unnecessary programs. if this doesn't work you might have to take your computer in to have someone do an optimization on all accounts. that will fix your problem.
Mar 01, 2009 | Microsoft Windows XP Home Edition
Logon
Go into your BIOS
Set the 1st Boot device preference to CD
Insert your windows XP disk
Boot from CD
Run XP Repair
You do this at your own risk. I am in no way accountable for damage to your computer.
Give me a message if you need further assistance
Blazamane
Jan 07, 2009 | Computers & Internet
Blank monitor
To resolve the problem,do the following step,
1. Power on the system
2. At dell logo screen before windows xp starts to load tap on the F8 key slowly 5 to 8 times
3. Select safe mode
4 Hit enter on the next screen and logon using the administrator or your name
5. Do the system restore, when you have logged on, this would return your system back to the date when it was working fine
6. To system restore
click start>all programs>accessories>system tools >system restore
Thanks
proton
Oct 11, 2008 | Dell Dimension 2400 PC Desktop
No Signal when desktop wants to load
It does not hate that monitor. I believe the problem is in the settings on your video. Your monitor cannot display them. You will most likely need to start your computer in safe mode and change the display settings on your video card or, alternatively, download updated video drivers. Also, if you can't get Windows to start in normal or safe mode, one of the options you get when you press F8 on startup is to start in VGA mode. That will get you in so you can tweak your settings, which are probably set to a resolution too high for your monitor.
Sep 11, 2008 | ViewSonic VA1916w LCD Monitor
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Logon
Can you describe the issue ion more detail?
Do you see a startup screen with the Windows Logo? Does the logon screen come up? Does the computer get out of the BIOS startup?
Nov 19, 2007 | Compaq Presario 7478 PC Desktop
Microsoft Windows XP Professional Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
