ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading electric machines, it may work on your gas model.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Hey friend, I appreciate your post!
I understand that your Electrolux gas dryer is making a loud vibration noise and is also loud while tumbling. There are several components in your dryer that could be causing this noise. Based off what you are describing it might be an issue with your suspension rollers, motor, or pulley. Since it could be any of these underlying issues I would suggest getting a technician out to diagnosis and repair your dryer. Hope this is helpful. - Matt
