Question about Polaroid TDA-03211C 32 in. LCD HDTV
32" polaroid lcd tv has picture for about 1 minute then smoke rolls from back of tv took back off found no wires burnt only smokes
  • Polaroid Master
  • 8,457 Answers
Now,turn on the tv again describe what the cause now like power LED light indication flashes or no power at all or have sound no video.Tell me the current cause of the tv now,so i will tries diagnose the problems and help u to buy refurbishes boards to fix it.
Posted on Oct 13, 2010
Seized up with smoke coming from the back of the TV
Check and replace the main power regulator board. Components on it have been burned due to voltage fluctuation. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 03, 2014 | Polaroid TDA-03211C 32 in. LCD HDTV
Sizzling,smoke,sparks ...horray.
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at www.tvrepairworld.com
Mar 13, 2013 | LG 32LD450 32 In. LCD HDTV
Screen is black and it smells like something is burning, but we cannot see any visable burnt wires or anything...we have removed the back of the tv, and looked at the circuit board...where exactly sho
Unless you know what you are doing you are playing with fire, Unplug the set and have someone qualified take a look at it. Smoke and a burning smell and you still have it powered up?
Apr 11, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
My 32 inch polaroid tlx-03210b red light stays on when plugged in then when i turn it on the blue appears and the audio from the tv i can hear but no visual
Hi breezeloe,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 30, 2011 | Polaroid TLX-01911C LCD TV
I was sitting home watching this television when all of a sudden I see smoke sizzling from the back!!OMG the television was on fire, it blacked out, but I could still hear the television show playing. The...
You need to look inside to see which board has smoked, I will suspect the power supply module. This is poorly designed TV!
See the pictures and the prices of the boards here:
http://www.shopjimmy.com/catalogsearch/result/?q=Polaroid+TDA-03211C
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 28, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Tv is smoking
Hi, Your TV has burnt capacitors, transformer / inductor that make your tv smokes. Please get it repair at dealer or trusted repair shop.
Regards,
Jan 22, 2011 | Protron PLTV3250 32 in. LCD Television
I saw a cloud of smoke come out of the back an now no picture but I do have sound.Its model TDA03211C 32 " dvd combo.
The smoke may have come from the main power supply. You can buy the whole module from Polaroid which includes, the power supply and the signal board all in one piece. I am not sure if this model has the inverters on the side or embedded with the panel. It may also be the inverter.
Best of luck.
Nour Sabre
Nov 03, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Smoke from rear of tv
I wouldn't turn it on either. Not needed, it won't work anyways, just cause more problems. You will need to have the rear panel removed and observe for shorted wires, burnt or swelled capacitors and likely a faulty power supply aka high voltage transformer
Apr 13, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Our Polaroid 32" tv died
well first of all smoke is never a good sign.probly has power supply issues.but anyway it should not be to hard to fix.should cost around $ 80 to $120 to fix .the hard part is going to find a service center that will give you a free est or close to free( under $20) or you could shearch out where the smoke came from should be fairly obvious and go from there
Mar 18, 2010 | Televison & Video
I was watching the tv, when the screen went blank but the voice was still on, then smelled something awful, like something plastic melting, then noticed a lot of smoke coming up from the back of the...
Most probably, Electrolytic condenser in the Power supply to display circuit may have punctured resulting in smoke coming out. Take tv to service centre. There is no other option.
Good luck.
Rating the solution is highly appreciated.
Mar 15, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid TDA-03211C 32 in. LCD HDTV Logo
366 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
