Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
I ran a scan on my 767nr and found a hard disk 1 needed to be replaced while replacing hard disk I decided to change from Vista to windows 7 but all function keys after main screen take me to a black screen that says operating system not found with disk in drive .Can windows 7 be loaded from disk only? if so how?
  • HP Master
  • 7,733 Answers
It Depends if your hardware support Win 7!
Posted on Oct 13, 2010
How to fix InPageCoFire error
this is a decide error code. Your hard drive may be having problems. I would suggest doing a disk scan
CHKDSK /R /F
as well as system file scan/repair
SFC /scannow
Do this from a DOS command line (make sure to run as administrator)
ex.
http://www.howtogeek.com/howto/windows-vista/guide-to-using-check-disk-in-windows-vista/
Feb 22, 2015 | Microsoft Windows 7 Home Premium 64BIT...
No OS found on disk
Make sure no other disks are plugged in (USB/CD/DVD), check BIOS for Boot Order, ensure your hard disk is 1st in order. If it still doesn't find the OS then you may have corrupted data, and potentially a defective disk. You can visit the hard disk manufacturer for a test utility for your hard disk and boot from it and scan the drive. It may even fix some errors.
You may also need to boot from an OS disk and select recovery console and run chkdisk /r on your main drive.
Jan 11, 2014 | Microsoft Windows Vista Home Premium with...
Bad sectors
Yes your hard drives electronics are failing. you need to replace your hard drive.
Jul 15, 2012 | Toshiba Satellite Computers & Internet
Dell Vostro 1500 Laptop: Without any obvious warning, my laptop will no longer boot into windows vista beyond the "microsoft corporation" screen with the green progress bar. it will get past the...
@rkbrown1_rb
If your Dell diagnostics shows no fault on the hardware (hdd, memory, chipset, videocard, etc.) but still same issue occurs, I recommend doing another test using a different utility. Try using Hiren's Boot CD that can be found here and try running the S&M Stress Test 1.9.1 and Video Memory Stress Test 1.7.116. If your computer hangs while doing the stress tests, the video card or CPU might be failing already.
Good Luck.
Sep 05, 2011 | Dell Vostro 1500 Notebook
1) HP Pavilion a6300f went dead only fans spining, replaced mother board with same make model, now ssytem boots but windows don't come up. 2) tried up grade from Vista Home to Vista professional to save...
For the first one, you need to enter BIOS and set the HDD settings. Maybe you can automatic detect it once and then the system knew where to load system from. If it can see the hard disk and reads it but no operating system found, then you may need to check the operating system on your hard disk.
For the second one, I do think it is better to upgrade to a upper level OS such as Windows 7. While you have Vista you will have better deal with Windows 7. If you do have a agreement with Microsoft to have newer OS for free in a certain period, you can get Windows 7 for free. If you don't have that agreement, you can get Upgrade version of windows 7 with a huge discount if you have Vista.
You can actually back up your data to an wim file on vista and restore all the data and settings after the upgrading. But be sure to keep a full backup of your hard disk and everything just in case.
You can enter BIOS and make sure booting from CD first. Then there is a key you need to press very early in the booting process to launch the recovery. There is also a factory default restore you can use. Did you call HP to find out what the key is and how to use factory default restoration? You can always plug the hard disk to other computer to back up the data and then restore to factory default and put the data back.
Apr 23, 2011 | HP Pavilion Desktop a6300f Intel Pentium...
I am using Intel845 motherboard and intel 2.4 p4 processor and 1gb ram. Can i install windows vista or windows 7 or microsoft server 2008 , is they supported to my Configuration. Any updates need to meet...
For Windows Vista to work : It requires minimum 2.0 ghz processor, 1 gb RAM and 60-80GB hard disk.
For Windows 7 : It requires minimum processor 3.0 ghz, 1 gb RAM and 60-80 GB hard disk.
Otherwise, your operating system or hardware problem will occur.
Dec 29, 2010 | Microsoft Computers & Internet
Can you give me any tips on how to start up my computer when it's saying operating system not found?
  1. Check the system setup, see if the hard disk drive is seen and identified in the bios. If not, reset defaults and see if it ID's
  2. Reseat the HDD, if #1 doesn't work
  3. If the HDD is seen, and Identified, but the system will not boot, then there may be a HDD problem. Run diags on the HDD< see of you get a failure. If you do, replace the HDD.
  4. If the drive passes diagnostics, then try booting to your Windows CD, press R for Recovery console (If XP, Choose Repair my Computer for Vista/7) run the command CHKDSK /R if XP
If that fails, then try a repair install of Windows, info can be found here:
http://www.fixya.com/support/r3874510-find_information_windows_installations
Jan 12, 2010 | Compaq Presario 1692 Notebook
I brought a toshiba from the pawn shop and i tried to change from windows xp to windows vista how can i find a hard drive disk to install windows vista
You don't need to replace the Hard drive in the laptop, you can usually upgrade, or install vista from the CD-ROM / DVD-Rom.
If your laptop does not have a DVD drive to install vista, you may use file sharing to install it from another computer on the network. To do this follow these steps:
1) Place the Vista DVD in second computer
2) right-click on the DVD-drive that has the Vista DVD in it, and select " Share..."
3) You may need to press the "Advanced sharing" button to enable sharing, if so, do that, and just hit the " apply " button
4) OK out of all of those menues
5) on your laptop open " my computer" and click the " map network drive "
6) browse to the location of your drive on the other computer, and click " OK "
7) install Windows vista
If you do however need a new hard drive for your laptop, you can usually get them from any PC store such as Bestbuy, fry's, or online from places such as NewEGG.com, and Tigerdirect.com.
You will need to know what type of hard drive you have, and how to replace it. The manual for your laptop usually has this type of information.
SIDE NOTE:
When putting Vista on a laptop, be sure it meets the minimum requirements.
May 30, 2009 | Toshiba Satellite® A75-S276 (PSA70U005004)...
Hard disk Recognition problem
U are actually facing the same problem as "jackwilkinso". As my previous post: Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Mar 29, 2009 | Western Digital Caviar 500GB Internal SATA...
Emachines 3240 - cannot recover
Download a Linux distro to a flash drive or DVD and see how well it runs off that. There's HDD utilities like SuperGrubDisk that can diagnose things.
Apr 04, 2017 | E-Machines Computers & Internet
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
100 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
