My computer dose not read my gogear - Computers & Internet
    Problem Solver:
  • 24 Answers
What's a gogear?
Posted on Oct 13, 2010
I ran the battery on my MP3 player completely down and it shut off. I charged it and now all the songs are gone... is there a way to recover the lost songs?
Try this:
1)Perform a system reset, which won't erase your files, to attempt to correct playback. Locate a thin object, such as pen tip or unfolded paper clip and insert it into the small reset hole on the bottom of your GoGear. Hold the thin object in place until you see the unit shut down completely. Your system has been reset. Power the device back on to see if the corrupted files have been corrected. If the reset failed to correct the issue, perform a file recovery on your GoGear.
2)Initiate a file recovery by first connecting your GoGear to your computer. From your computer's "Start" menu, choose "Programs," "Philips Digital Audio Player," "Area Device Manager" and "Philips Device Manager." The Philips Device Manager software will be activated. Inspect your GoGear to confirm that it is turned off. Plug the small end of the supplied USB cord into the bottom of your GoGear while holding down the "Volume Up." Insert the larger end into a free USB port on your computer. Hold the key as the "Philips Device Manager" reads your GoGear and activates recovery mode. Click "Repair" and follow the onscreen prompts as given by the "Philips Device Manager" to complete the process of memory recovery. Disconnect your GoGear from your computer properly after the process is complete and restart your MP3 player.
3)Reload and replace the files onto your GoGear by first connecting your GoGear to your computer. Plug the supplied USB cord's small end into the bottom of your GoGear and the large end into your comptuer's USB port. Initiate Windows Media Player by clicking on its icon if it doesn't start upon connection with your GoGear. In the left pane of the WMP, click "Philips GoGear Aria." Click the arrow on the top left edge of the WMP window, followed by "Music." Highlight all files, and click "Delete." Click the "Sync" tab on WMP, and drag and drop the music files you would like to replace and reload into the "Sync List" panel. Click "Start Sync." The files will be freshly loaded onto your GoGear.
4)Properly disconnect your GoGear from your computer to avoid memory corruption by first closing all applications in use by the GoGear (WMP). Click the USB device icon in your system's tray (located on the bottom right corner of your screen). Follow the prompts in order to safely remove your GoGear from your computer. When your computer tells you it's safe to remove your GoGear, unplug the USB cord from your GoGear.
Hope this helps!
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
My philips gogear sa1356 was not working properly after formating it through computer,i think i just lost system files...?Player was not reading any mp3 or any other files after format
Your going to need to download and install the GOGEAR files from the gogear.com homepage under support. Once you do this, you will need to leave the files on your computer and then move the files onto the GOGEAR player. Keep ind mind that if you had music or data on the player before, that information will now be lost and not recoverable.
Jan 20, 2011 | Philips GoGear SA1335 MP3 Player
It cant be read by computer
it cant be read by my computer my philips gogear sa52xx 4gb flash video player mp3?
Oct 22, 2010 | Philips GOGEAR SA6045 MP3 Player
My computer dose not reconize my gogear
Try to press the power button while it is connected to your computer. See if it will show up charging. If it is not, then you may need to contact Philips Support.
Oct 13, 2010 | Philips GOGEAR SA6045 MP3 Player
My philps GOGEAR HAS STOP COMEING/WILL NOT GOIN TO USB MODE
Could have a dead battery, try replacing the battery....
Aug 21, 2009 | Philips GoGear SA3125/37 MP3 Player
Reading
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Apr 03, 2008 | Philips HDD065 MP3 Player
Image not aviable
First, make sure the album art is in jpeg format.
If so, then read this to make sure you have installed the Philips Plug-In - it is essential for proper image transferring:
Is the Philips Device Plug-in installed on your computer? Immediately after you have transferred your
pictures in Windows Media Player, you should see a Philips screen pop-up. If it does not appear, then the
Plug-in is probably missing. To check whether this Plug-in is available on your computer, go to Control
Panel > Add or Remove Programs and check if Philips Device Plug-in is listed. If not, re-install the
software from the supplied CD.
Mar 09, 2008 | Philips GoGear HDD6330 MP3 Player
Getting music off
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Feb 19, 2008 | Philips GOGEAR SA6045 MP3 Player
SA6045
Repair the GoGear (This will permanently delete all files form device):
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
-Tha Mp3 Doctor
Jan 14, 2008 | Philips SA3125\02 MP3 Player
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
