Question about Uniden DCT758-2 Twin Cordless Phone
How do I change handset 2 so that it will ring with incoming call? The screen shows 'ringer off'" and I do not seem to be able to change it.
  • 3 more comments
  • heather_s827 Oct 13, 2010
    Uniden DCT758 Thanks - hopefully you can help.
  • heather_s827 Oct 14, 2010
    Uniden DCT758. Screen on 2nd handset shows 'ringer off' and no sound when a call comes in, but handset 1 is fine. How do I turn the ringer on on 2nd handset? The Do not disturb option works on man phone 1 only.
    Thanks but I have the manual and it is no help in this case. Any other suggestions?
  • heather_s827 Oct 18, 2010
    Thanks for info, but I tried all of that and still it shows 'ringer off' - am beginning to wonder if that is the way it is supposed to be! Any other suggestion would be appreciated.
    Thanks for trying to help, but I have now managed to get a reply from supplier and it appears phone is faulty so it has been returned for replacement or repair. Any further problems I will contact you again, but in the meantime will wait and see what happens when it is returned. Thanks again.
  • 2,973 Answers
Heather,
Please follow the link below to download the Manual for your phone. It contains everything that you may ever need.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Oct 14, 2010
  • Rinoo Kumari Oct 14, 2010
    Please try powering it off and then on after a few minutes. It helps sometimes. And if it does not work then set it up from the begining as if you are doing it for the first time on a new phone. And also reset the frequency to match that of the base unit. You may have to do it on both handsets.
  • Rinoo Kumari Oct 18, 2010
    Heather,
    Have you reset the phone? Please reset the frequency on the base and match it on the two handsets. It seems that phone 1 Is matched and 2 is not. If they are on the same frequency then they both will function in the same manner. The user guide had the method to realign the frequency on all three, base and two handsets.
  • 8,197 Answers
May I get the make and model # to help you more
Posted on Oct 13, 2010
  • Jyackle5
    Jyackle5 Oct 13, 2010
    Do Not Disturb (All Calls)
    Do not disturb (DND) allows you to mute the ringer of all stations at once. With the phone in standby, press and hold
    [dnd] on the base. You will hear a confirmation tone and the dnd LED illuminates. To cancel, press [dnd] again. You
    can also mute the ringer tone while the phone is ringing by pressing [dnd] on the base.
    Note: If the answering system is off, it will automatically turn on when you activate dnd. If
    you turn the answering system off while dnd is on, dnd automatically turns off along
    with the answering system.
    Or you can look at the manual on the link below page 38.
    http://www.uniden.com/pdf/DCT758om.pdf
    Good Luck please accept the answer and please leave a testimonial
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Oct 17, 2014 | Uniden DECT 6.0 Cordless Telephone...
A180 just showing base and no response
Is the ringer turned off? Or is the volume on the ring tone set too low? Another possibility is that the phone isn't set to receive incoming calls - the Siemens phones I've owned allowed one to specify which handsets could handle incoming calls and outgoing calls on each line.
Jun 01, 2014 | Siemens Lands Phones
Somehow the ringer got turned off. Can't figure
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
Handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Mar 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Uniden Phone
goto the name and hit store it will restore the name and when going threw the store process it should show you old parameters
or goto phonebook find name and edit its preferences for that name phone ringers are set ringers so when you pick one for gereral use thats going to be the general use ringer but special ringers is what i descriped in first part
menu handset setup then ringers for a general ringer you can change to a more pleasing ringer but over all cant turn off
May 10, 2008 | Uniden Cordless Phone
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Oct 12, 2007 | RCA H5450RE3 Accessory Handset For -25450...
Uniden DCT758-2 Twin Cordless Phone Logo
26 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
