Question about RCA P46921 46" Rear Projection Television
I HAVE A RCA PROJECTION TV MODEL # P46924. SET WILL NOT TURN ON AND DOES NOT MAKE ANY NOISES.
  • RCA Master
  • 6,993 Answers
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Oct 13, 2010
RCA P46924 Rear Projection screen has sound but no picture.
A older but trouble free model in most cases.
I gather you get no menu or any light on the screen and have tried tuner and at least one rear input.
Fist thing just to look for is with rear cover removed do the three round black lens light up at all?
The set could have a number of issues possible if they do not, No high voltage, no Filament voltage to the tubes etc.
Let me know as much as possible including your skill level with TV sets.
Dec 16, 2012 | RCA P46924 46" Rear Projection Television
Model number p46151wk, can turn tv on with power button but automatically turns back off
A number of possible answers---I need to know two things= on back of set aside from model number is there a chassis number like PTK 195 etc? Is power light green and going off or remains on?
Aug 27, 2012 | RCA P46924 46" Rear Projection Television
Hello! I'm having a problem changing the video source of my TV to use my Roku player How do you change the video source to Video 1 or 2 TV model number RCA P46924 PLEASE HELP ME ASAP
on the remote there should be a button that says input, you can do it that way or there should be a button on your tv that says menu then goto the video settings and find the input
Jul 01, 2011 | RCA P46924 46" Rear Projection Television
Where is the reset button on an rca model#p46924 46" projection screen tv?
Hello
Reset button is on its remote control itsef. You can locate it at the bottom right side. Point it towards TV, and reset the setting you want to. OK.
Apr 22, 2011 | RCA P46924 46" Rear Projection Television
TV doesn't have picture
it could be several things..no high voltage..bad tube...crt board problem..suggest you take to repair shop...compare prices of new tvs...repair at least 150$
Mar 22, 2009 | RCA P46924 46" Rear Projection Television
RCA P46924 46" Rear Projector TV
First of all, we need to determine whether the power supply has a problem or if it is being told to shutdown because of a problem detected in the set. Are you familiar with electronics repair? Do you have a meter?
Dan
Sep 10, 2008 | RCA P46924 46" Rear Projection Television
RCA P46924 46 in rear projection tv will not turn on
More than likely it has bad solder connections on the circuit board. You could try tapping lightly on power supply/deflection boards to see if it makes contact. Usually I find bad solder on those right under where the power cord plugs in, on the bottom of the board. If you have a soldering iron and solder you could save a few hundred dollars in repair costs, but use caution and make sure all power to set is disconnected. Maybe mark each plug as you disconnect them. Hope this helps. Good luck, Russmann.
Jun 02, 2008 | RCA P46924 46" Rear Projection Television
RCA P46921 46" Rear Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
