Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
5300 CAN'T GET A CALIBRATION PAGE. GOES TO PAPER JAM. I FOLLOWED THOSE INSTRUCTIONS. NO PAPER JAM. IT'[S STUCK ON "PLEASE WAIT" . CAN'T FORCE CALIBRATION.
    Scholar:
  • 75 Answers
I have seen this when I have stored/used my printers in a humid location - in my case, my basement home office. The paper edges curl enough to interfere with the grippers and/or cause paper jams.
Make sure you have new, dry paper (perfectly flat) in the tray and try again. If this solves the problem, you may want to try to relocate your printer to a dryer location.
Good luck.
DigiChick
Posted on Jun 09, 2008
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
NeatDesk scanner
paper feeds on printers and scanners can be seriously damaged by thick paper jams. Aside from actually taking the unit apart (which can be daunting) try sliding heavy card stock through the paper path. Don't force it. Sometimes cutting it into a narrow strip (3 or 4 ") helps it slide through.
Mar 05, 2014 | Neat Company NeatDesk Scanner
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    I was trying to print envleopes 7.25" x 5.25" with
    In the printer properties go to features and then go to resizing;custom options and choose your print job.
    If you need more help come back.Post / thumbs / testimonial are welcome!
    Nov 28, 2010 | HP Photosmart C7280 Printer
    Dell 922 saying there is a paper jam
    First try this. Turn off the printer, remove all the cartridges, drum, open all the doors and remove all the trays. Now verify that there's no actual paper jam by exploring through the inside of the printer. You can use a blower to blow any dust or pieces of paper, etc.. from the printer. Now use the manual feed and put in thicker paper several times (push in and pull out). Again reinstall and reconnect every components and boot the printer. If the actual printer's paper sensor isn't broken or stuck or twisted, this will definitely clear the paper jam message on the printer.
    If the problem persists, please download this small text file and follow the instructions (click here). Open the link, click "Download Now" button, wait for 20 seconds and again click "Download File Now" link and read the instructions and follow step by step.
    Good luck.
    Thanks for using FixYa.
    Jul 16, 2010 | Dell 922 All-In-One InkJet Printer
    Canon MP830 will not print Error code 5C10, And 5100 donaldbetty@juno.com
    5C10 seems to indicate a paper jam. 5100 indicates either a paper jam or ink tanks not seated properly.
    A) Paper jam: There is a rear cover on this model. Many paper jams cannot be seen from the outside. Sometimes even a scrap of paper from a previous jam will disrupt the paper path.
    B) Follow your manual for installation of the ink tanks. Remove and replace the ink tanks carefully following the instructions.
    C) Should these remedies not fix the problem, you can try resetting the device:
    1) Press and hold the <On/Off> button until the display on the machine goes blank. (If this is unsuccessful, unplug the power cord).
    2) Wait approx. 10 seconds and power back on. Wait until the printer completes its startup routine before trying another print job.
    3) If solution fails, your MP 830 may require repair
    Dec 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Printer won't print. Flashing red light. No paper jam and ink cartridges are ok. Please help!!
    Per the manual, it's 99.9 % one of these causing the issue. The other .1 % should take it back or get a new one.
    The printer requires attention. Try the following:
    ● If the printer is connected to a computer, check the computer screen for
    instructions. If the printer is not connected to a computer, check for the following
    problems:
    – Top cover open
    – Out of paper
    – Paper jam
    – Print carriage jammed or stuck
    – Print cartridge inserted incorrectly
    – Incorrect print cartridge installed
    ● If you are unable to solve the problem by using the instructions above, turn off the
    printer and unplug the printer's power cord. Wait one minute, then plug it in again.
    Turn on the printer.
    Sep 29, 2009 | HP Photosmart 7450 InkJet Printer
    Kodak All-in-one Printer has Paper Jam problem
    Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
    Sep 15, 2009 | Kodak ESP 5 Printer
    Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
    Try this one
    Take out the inks and printhead
    Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
    Close the cartridge door once the cord is unplugged
    Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
    Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
    Thanks Josh - Kodak Tech Support
    Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
    114 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
