Question about Magellan Maestro 4210 Car GPS Receiver
I own a magellan maestro 4210 and i can't seem to find where i left the software that came with it. My question is where can i find the right software FREE and updates Thank you
SOURCE: magellan maestro 3100 failed update
go to Tech support at www.magellamgps.com tell them what has transpired and ask for 2.18 Update Recovery Files. This fixed my problem. Took a few email exchanges but I thought the responses were very quick.
Posted on Mar 13, 2009
SOURCE: magellan 3250 won't update
Hi, I had the same problem with my 3200. Got the update, and it bricked my unit. After 3 weeks of searching the net for solutions, all of which did not work, I called Magellan Tech Support today. Simply told them that I was updating the maps, update failed, and now the unit will not boot past the blue magellan screen with the progress bar. They asked for some information, including the email address that you used to register the product, and the serial number of the unit, as well as the map update information...which you had to register to get the unlock code. They are able to see all of this c in their tests on the unit, which of course did not work. I was then given a RA#, and account #, and was assured that I would get a pre-paid shipping label via email within 24 hours. All you have to do is pack the unit and take it to fed-ex with the label. They will fix your unit with the updated maps, and return it to you via Fed-Ex. Took no longer than 15 minutes on the phone, which beats the 3 weeks of research that did not help. Problem solved. Just call Tech Support, this is a well-known problem, and they will fix your unit and update the map. Hope this helps.
Posted on Mar 26, 2009
  • 34 Answers
SOURCE: Magellan Maestro is stuck on
Have you tried to reset the GPS, there is a small hole on the side, use a pen, push it in and wait for it to reboot. You may have to do it a couple of time, my sister in law had the same issue and I was able to get it back up and running.
Posted on Jul 16, 2009
  • 145 Answers
SOURCE: how to update the system of magellan maestro 4210?
http://www.magellangps.com/support/product.asp?prodid=1955
If you follow the link above you should find everything you need.
You may need to register your device, but all downloads and updates are available here.
Jim
Posted on Aug 04, 2009
toy_ladi
  • 484 Answers
SOURCE: Magellan Maestro 4040 update
There is no recent software updates for your magallen maestro 4040.
You just have to wait till a new one comes out.
But the most recent for now is the rev 2.26 version you are having.
When there is a new software update, you can find out through this link,
http://www.magellangps.com/support/product.asp?prodid=1873
Take care
Posted on Jul 04, 2010
Tip
Magellan Maestro units Reset button - look at the bottom of the unit , there...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jan 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Magellan 4210 from texas wont work here in the philippines, help pls thanks
You need to have the Philippine maps installed.
Please dont forget to vote if you liked my answer
thanks
Feb 10, 2011 | Magellan Maestro 4210 Car GPS Receiver
Megellan Maestro 4210 gps slow to find current location
I recommend you to reset it . Resetting should solve this problem .
Here is how to reset your Maestro :
1:Locate the button marked "Reset" on the left, right or bottom of the unit.
2:Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
3:If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
PLEASE DON'T FORGET TO RATE !
Apr 14, 2010 | Magellan Maestro 4210 GPS Receiver
Half of the screen is white
Try this, turn the unit on and off two times, see if this corrects the problem.
Make sure the unit is fully charged also.
Now, after the unit is fully charged, and you try as I said above, you have one more option.
Look on the top and bottom of the unit for a pin hole that says reset,
if the unit has a reset hole, stick a paper clip in it for 30 seconds.
If you still have a problem, there is a software update and a map update for the unit, you can do this, or just email the company and tell them your problem and see what they will do.
After reading your manual, I don't see a restore to original condition,
so I seem to think your best option is to contact them and send in the unit.
This is the support page for the company, manual, updates, but you can go to the right side and get help with repair.
Good luck.
Feb 07, 2010 | Magellan Maestro 4210 GPS Receiver
How to update the system of magellan maestro 4210?
Jim
Aug 04, 2009 | Magellan Maestro 4210 Car GPS Receiver
Magellan Maestro 4210 no audio or garbled sound
I suggest you take it back to the seloloer before the warranty expires
Jul 20, 2009 | Magellan Maestro 4210 Car GPS Receiver
Switch from true view to map view on the magellan 3250?
You didn't state your model but on my Maestro 3210 and 4210 it's MENU USER OPTIONS MAP OPTIONS
Jan 12, 2009 | Magellan Maestro 3200 GPS
WILL NOT FIND SATELLITES
Go to the Magellan site and search the support section. Send a detailed question to their support staff, yes I know their slow but if you try Maggie it's like pulling your owne teeth with tweezers
Jan 03, 2009 | Magellan Maestro 4210 GPS Receiver
Magellan Maestro 4210 Car GPS Receiver Logo
42 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
